Page 1 of 1
Error message in zoneminder when starting ZMninja
Posted: Wed May 28, 2025 1:18 pm
by Figge71
Hi!
I see myself as a newbie, even if I've hade Zoneminder a long time. I've probable been one of the lucky ones or I might just be stubborn.
My system
Centos stream 9, minimal installation
5.14.0-585.el9.x86_64
Zoneminder ver. 1.36.35
Hardware
MSI motherboard
Intel Core i9-9900 CPU 3.10GHz
Memory 128mb
Camera 20pcs no name cameras
I get som minor errors, but nothing major.
After needing to reinstall the system, I've goten som problems with ZMninja.
When starting ZMninja I get several similar error messages that i'm having trubbel finding a solution for. I've reinstalled the system a few times been searching for a week.
When looking in the log files I can only find the same message that I see in the web portal logs.
I hope I haven't missed any vital information.
Wish everyone a plesent day, evening, night, depending on where you are or when you read this :)
5/26/25, 8:35:37 PM UTC.326839 web_php[1278].ERR [192.168.176.33] [Socket /var/lib/zoneminder/sock/zms-921523s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.] at /usr/share/zoneminder/www/includes/functions.php line 1884
5/26/25, 8:35:37 PM UTC.328012 web_php[1307].ERR [192.168.176.33] [Socket /var/lib/zoneminder/sock/zms-946636s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.] at /usr/share/zoneminder/www/includes/functions.php line 1884
5/26/25, 8:35:37 PM UTC.329111 web_php[44182].ERR [192.168.176.33] [Socket /var/lib/zoneminder/sock/zms-851489s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.] at /usr/share/zoneminder/www/includes/functions.php line 1884
5/26/25, 8:35:37 PM UTC.331359 web_php[44185].ERR [192.168.176.33] [Socket /var/lib/zoneminder/sock/zms-158092s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.] at /usr/share/zoneminder/www/includes/functions.php line 1884
5/26/25, 8:35:37 PM UTC.332201 web_php[43544].ERR [192.168.176.33] [Socket /var/lib/zoneminder/sock/zms-521949s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.] at /usr/share/zoneminder/www/includes/functions.php line 1884
5/26/25, 8:35:37 PM UTC.337737 web_php[1299].ERR [192.168.176.33] [Socket /var/lib/zoneminder/sock/zms-033074s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.] at /usr/share/zoneminder/www/includes/functions.php line 1884
5/26/25, 8:35:37 PM UTC.337690 web_php[39370].ERR [192.168.176.33] [Socket /var/lib/zoneminder/sock/zms-521609s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.] at /usr/share/zoneminder/www/includes/functions.php line 1884
5/26/25, 8:35:37 PM UTC.338791 web_php[43543].ERR [192.168.176.33] [Socket /var/lib/zoneminder/sock/zms-170135s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.] at /usr/share/zoneminder/www/includes/functions.php line 1884
5/26/25, 8:35:37 PM UTC.339683 web_php[44139].ERR [192.168.176.33] [Socket /var/lib/zoneminder/sock/zms-740578s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.] at /usr/share/zoneminder/www/includes/functions.php line 1884
5/26/25, 8:35:37 PM UTC.369516 web_php[44790].ERR [192.168.176.33] [Socket /var/lib/zoneminder/sock/zms-115270s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.] at /usr/share/zoneminder/www/includes/functions.php line 1884
