Page 1 of 1
Cycle -- countdown stops, re-initializing values
Posted: Sat Apr 12, 2025 3:29 am
by busymind
Discovered by accident.
I just upgraded for 1.37.66.271 the cycle stop working once down count value of seconds = 1.
At some point was looping trough each camera for an given amount set of pause.
also when changing value the count down is not set
Re: Cycle -- countdown stops, re-initializing values
Posted: Sat Apr 12, 2025 12:52 pm
by IgorA100
Sorry.
Yes, this issue appeared yesterday during the optimization of the loading speed of the "Material icons" fonts
I created a PR https://github.com/ZoneMinder/zoneminder/pull/4308
Posted: Sun Apr 13, 2025 10:19 pm
by busymind
just as notice,
1. modified manually, worked ok, up to the latest upgrade 1.37.66.273 then stopped working after upgrade.
2. also if you leave the browser open for long time the log shows - cookie expire, cycling continue ?
ERR Unable to authenticate user from http://zm.luparu.local/zm/index.php?vie ... true&mid=1.
3. I suppose when cycling, load events is set "load all", a high CPU is seen because cycling seems loading all the events in background .
