Like this one:
[Tue Jan 28 15:25:55 2025] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=init.scope,mems_allowed=0,global_oom,task_memcg=/system.slice/zoneminder.service,task=zmc,pid=357287,uid=33
[Tue Jan 28 15:25:55 2025] Out of memory: Killed process 357287 (zmc) total-vm:30176312kB, anon-rss:14747924kB, file-rss:4352kB, shmem-rss:8064kB, UID:33 pgtables:58372kB oom_score_adj:0
[Tue Jan 28 15:25:57 2025] systemd[1]: snapd.service: Watchdog timeout (limit 5min)!
[Tue Jan 28 15:25:57 2025] systemd[1]: snapd.service: Killing process 344943 (snapd) with signal SIGABRT.
[Tue Jan 28 15:25:57 2025] oom_reaper: reaped process 357287 (zmc), now anon-rss:0kB, file-rss:88kB, shmem-rss:0kB
[Tue Jan 28 15:25:58 2025] systemd[1]: snapd.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
[Tue Jan 28 15:25:58 2025] systemd[1]: snapd.service: Failed with result 'watchdog'.
[Tue Jan 28 15:25:58 2025] systemd[1]: Created slice user-1000.slice - User Slice of UID 1000.
[Tue Jan 28 15:25:58 2025] systemd[1]: Starting
user-runtime-dir@1000.service - User Runtime Directory /run/user/1000...
[Tue Jan 28 15:25:58 2025] systemd[1]: Finished
user@1000.service - User Manager for UID 1000...
[Tue Jan 28 15:25:58 2025] systemd[1]: snapd.service: Scheduled restart job, restart counter is at 4.
[Tue Jan 28 15:25:58 2025] systemd[1]: Starting snapd.service - Snap Daemon...
[Tue Jan 28 15:25:58 2025] systemd[1]: Started
[Tue Jan 28 15:25:58 2025] systemd[1]: Started session-414.scope - Session 414 of User migo.
[Tue Jan 28 15:25:58 2025] systemd[1]: systemd-journald.service: Main process exited, code=dumped, status=6/ABRT
[Tue Jan 28 15:25:58 2025] systemd[1]: systemd-journald.service: Failed with result 'watchdog'.
[Tue Jan 28 15:25:58 2025] systemd[1]: systemd-journald.service: Consumed 3min 11.939s CPU time.
[Tue Jan 28 15:25:58 2025] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 3.
[Tue Jan 28 15:25:58 2025] systemd[1]: Starting systemd-journald.service - Journal Service...
[Tue Jan 28 15:25:58 2025] systemd-journald[369628]: Collecting audit messages is disabled.
[Tue Jan 28 15:25:58 2025] systemd-journald[369628]: File /var/log/journal/5105103edaba44fabd4c9dab6f5886da/system.journal corrupted or uncleanly shut down, renaming and replacing.
[Tue Jan 28 15:25:58 2025] systemd[1]: Started systemd-journald.service - Journal Service.
[Tue Jan 28 15:25:59 2025] systemd-journald[369628]: /var/log/journal/5105103edaba44fabd4c9dab6f5886da/user-1000.journal: Journal file uses a different sequence number ID, rotating.
[Tue Jan 28 15:25:59 2025] loop6: detected capacity change from 0 to 8
[Tue Jan 28 18:39:39 2025] workqueue: delayed_fput hogged CPU for >10000us 4 times, consider switching to WQ_UNBOUND
[Fri Jan 31 06:52:57 2025] audit: type=1400 audit(1738302777.538:145): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/sbin/mysqld" pid=637067 comm="apparmor_parser"
[Fri Jan 31 06:53:12 2025] audit: type=1400 audit(1738302792.841:146): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/sbin/mysqld" pid=637477 comm="apparmor_parser"
[Fri Jan 31 08:20:41 2025] systemd-journald[369628]: Under memory pressure, flushing caches.
[Fri Jan 31 08:20:42 2025] systemd-journald[369628]: Under memory pressure, flushing caches.
[Fri Jan 31 08:20:47 2025] systemd-journald[369628]: Under memory pressure, flushing caches.
[Fri Jan 31 08:20:51 2025] systemd-journald[369628]: Under memory pressure, flushing caches.
[Fri Jan 31 08:20:56 2025] systemd-journald[369628]: Under memory pressure, flushing caches.
[Fri Jan 31 08:21:00 2025] systemd-journald[369628]: Under memory pressure, flushing caches.
[Fri Jan 31 08:21:05 2025] systemd-journald[369628]: Under memory pressure, flushing caches.
[Fri Jan 31 08:22:19 2025] systemd-journald[369628]: Under memory pressure, flushing caches.
[Fri Jan 31 09:06:03 2025] zmc invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
[Fri Jan 31 09:06:03 2025] CPU: 3 PID: 648259 Comm: zmc Tainted: G U 6.8.0-51-generic #52-Ubuntu
[Fri Jan 31 09:06:03 2025] Hardware name: LENOVO 10SUS4430B/312A, BIOS M1UKT47A 08/14/2019
[Fri Jan 31 09:06:03 2025] Call Trace:
[Fri Jan 31 09:06:03 2025] <TASK>
[Fri Jan 31 09:06:03 2025] dump_stack_lvl+0x76/0xa0
[Fri Jan 31 09:06:03 2025] dump_stack+0x10/0x20
[Fri Jan 31 09:06:03 2025] dump_header+0x47/0x1f0
[Fri Jan 31 09:06:03 2025] oom_kill_process+0x118/0x280
[Fri Jan 31 09:06:03 2025] ? oom_evaluate_task+0x143/0x1e0
[Fri Jan 31 09:06:03 2025] out_of_memory+0x103/0x350
[Fri Jan 31 09:06:03 2025] __alloc_pages_may_oom+0x10c/0x1d0
[Fri Jan 31 09:06:03 2025] __alloc_pages_slowpath.constprop.0+0x420/0x9f0
[Fri Jan 31 09:06:03 2025] __alloc_pages+0x31f/0x350
[Fri Jan 31 09:06:03 2025] alloc_pages_mpol+0x91/0x210
[Fri Jan 31 09:06:03 2025] folio_alloc+0x64/0x120
[Fri Jan 31 09:06:03 2025] ? filemap_get_entry+0xe5/0x160
[Fri Jan 31 09:06:03 2025] filemap_alloc_folio+0xf4/0x100
[Fri Jan 31 09:06:03 2025] __filemap_get_folio+0x14b/0x2f0
[Fri Jan 31 09:06:03 2025] filemap_fault+0x15c/0x8e0
[Fri Jan 31 09:06:03 2025] __do_fault+0x38/0x140
[Fri Jan 31 09:06:03 2025] do_read_fault+0x133/0x1d0
[Fri Jan 31 09:06:03 2025] do_fault+0x109/0x350
[Fri Jan 31 09:06:03 2025] handle_pte_fault+0x114/0x1d0
[Fri Jan 31 09:06:03 2025] __handle_mm_fault+0x653/0x790
[Fri Jan 31 09:06:03 2025] handle_mm_fault+0x18a/0x380
[Fri Jan 31 09:06:03 2025] do_user_addr_fault+0x169/0x670
[Fri Jan 31 09:06:03 2025] exc_page_fault+0x83/0x1b0
[Fri Jan 31 09:06:03 2025] asm_exc_page_fault+0x27/0x30
[Fri Jan 31 09:06:03 2025] RIP: 0033:0x5f3cffd61790
[Fri Jan 31 09:06:03 2025] Code: Unable to access opcode bytes at 0x5f3cffd61766.
[Fri Jan 31 09:06:03 2025] RSP: 002b:0000768e757ff3c8 EFLAGS: 00010246
[Fri Jan 31 09:06:03 2025] RAX: 0000000000000006 RBX: 0000000000000000 RCX: 00005f3d05ca5968
[Fri Jan 31 09:06:03 2025] RDX: 0000000100000006 RSI: 0000000000000028 RDI: 0000768e784b64d0
[Fri Jan 31 09:06:03 2025] RBP: 0000768e757ff420 R08: 0000000000000000 R09: 0000000000000000
[Fri Jan 31 09:06:03 2025] R10: 0000000000000000 R11: 0000000000000293 R12: 00005f3d05ca5960
[Fri Jan 31 09:06:03 2025] R13: 00005f3d05ca5970 R14: 0000768e8a60b040 R15: 00005f3d05ca5968
[Fri Jan 31 09:06:03 2025] </TASK>
[Fri Jan 31 09:06:03 2025] Mem-Info:
[Fri Jan 31 09:06:03 2025] active_anon:5511399 inactive_anon:368895 isolated_anon:0
active_file:687 inactive_file:1435 isolated_file:0
unevictable:38237 dirty:0 writeback:0
slab_reclaimable:68668 slab_unreclaimable:39009
mapped:31576 shmem:32076 pagetables:16000
sec_pagetables:0 bounce:0
kernel_misc_reclaimable:0
free:38988 free_pcp:2629 free_cma:0
[Fri Jan 31 09:06:03 2025] Node 0 active_anon:22045596kB inactive_anon:1475580kB active_file:2968kB inactive_file:5300kB unevictable:152948kB isolated(anon):0kB isolated(file):0kB mapped:126304kB dirty:0kB writeback:0kB shmem:128304kB shmem_thp:4096kB shmem_pmdmapped:0kB anon_thp:241664kB writeback_tmp:0kB kernel_stack:5424kB pagetables:64000kB sec_pagetables:0kB all_unreclaimable? no
[Fri Jan 31 09:06:03 2025] Node 0 DMA free:11264kB boost:0kB min:40kB low:52kB high:64kB reserved_highatomic:0KB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15992kB managed:15360kB mlocked:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[Fri Jan 31 09:06:03 2025] lowmem_reserve[]: 0 2307 23814 23814 23814
[Fri Jan 31 09:06:03 2025] Node 0 DMA32 free:91544kB boost:0kB min:6540kB low:8900kB high:11260kB reserved_highatomic:0KB active_anon:2076332kB inactive_anon:223036kB active_file:140kB inactive_file:1232kB unevictable:0kB writepending:0kB present:2494164kB managed:2428212kB mlocked:0kB bounce:0kB free_pcp:1716kB local_pcp:0kB free_cma:0kB
[Fri Jan 31 09:06:03 2025] lowmem_reserve[]: 0 0 21506 21506 21506
[Fri Jan 31 09:06:03 2025] Node 0 Normal free:53144kB boost:0kB min:60996kB low:83016kB high:105036kB reserved_highatomic:0KB active_anon:19969068kB inactive_anon:1252740kB active_file:792kB inactive_file:5804kB unevictable:152948kB writepending:0kB present:22519808kB managed:22030112kB mlocked:142500kB bounce:0kB free_pcp:8800kB local_pcp:4kB free_cma:0kB
[Fri Jan 31 09:06:03 2025] lowmem_reserve[]: 0 0 0 0 0
[Fri Jan 31 09:06:03 2025] Node 0 DMA: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 1*1024kB (U) 1*2048kB (M) 2*4096kB (M) = 11264kB
[Fri Jan 31 09:06:03 2025] Node 0 DMA32: 518*4kB (UE) 742*8kB (UME) 659*16kB (UME) 474*32kB (UE) 247*64kB (UME) 127*128kB (UME) 55*256kB (UME) 14*512kB (UME) 4*1024kB (UME) 0*2048kB 0*4096kB = 91128kB
[Fri Jan 31 09:06:03 2025] Node 0 Normal: 3233*4kB (UME) 748*8kB (UME) 1653*16kB (UME) 219*32kB (UME) 3*64kB (U) 1*128kB (U) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 52692kB
[Fri Jan 31 09:06:03 2025] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB
[Fri Jan 31 09:06:03 2025] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[Fri Jan 31 09:06:03 2025] 37017 total pagecache pages
[Fri Jan 31 09:06:03 2025] 0 pages in swap cache
[Fri Jan 31 09:06:03 2025] Free swap = 0kB
[Fri Jan 31 09:06:03 2025] Total swap = 0kB
[Fri Jan 31 09:06:03 2025] 6257491 pages RAM
[Fri Jan 31 09:06:03 2025] 0 pages HighMem/MovableOnly
[Fri Jan 31 09:06:03 2025] 139070 pages reserved
[Fri Jan 31 09:06:03 2025] 0 pages hwpoisoned
[Fri Jan 31 09:06:03 2025] Tasks state (memory values in pages):
[Fri Jan 31 09:06:03 2025] [ pid ] uid tgid total_vm rss rss_anon rss_file rss_shmem pgtables_bytes swapents oom_score_adj name
[Fri Jan 31 09:06:03 2025] [ 447] 0 447 72279 6816 4640 2176 0 114688 0 -1000 multipathd
[Fri Jan 31 09:06:03 2025] [ 469] 0 469 7243 963 419 544 0 81920 0 -1000 systemd-udevd
[Fri Jan 31 09:06:03 2025] [ 847] 102 847 5386 1248 576 672 0 86016 0 0 systemd-resolve
[Fri Jan 31 09:06:03 2025] [ 848] 104 848 22735 992 224 768 0 94208 0 0 systemd-timesyn
[Fri Jan 31 09:06:03 2025] [ 889] 101 889 4718 928 256 672 0 81920 0 0 systemd-network
[Fri Jan 31 09:06:03 2025] [ 948] 103 948 2439 960 128 832 0 61440 0 -900 dbus-daemon
[Fri Jan 31 09:06:03 2025] [ 951] 0 951 272182 6080 5088 992 0 1376256 0 0 fail2ban-server
[Fri Jan 31 09:06:03 2025] [ 966] 0 966 4520 928 224 704 0 81920 0 0 systemd-logind
[Fri Jan 31 09:06:03 2025] [ 984] 0 984 673 352 0 352 0 49152 0 0 atopacctd
[Fri Jan 31 09:06:03 2025] [ 1003] 107 1003 55627 1181 349 832 0 94208 0 0 rsyslogd
[Fri Jan 31 09:06:03 2025] [ 1038] 0 1038 1706 512 32 480 0 57344 0 0 cron
[Fri Jan 31 09:06:03 2025] [ 1039] 65534 1039 3546 1120 320 800 0 73728 0 0 openvpn
[Fri Jan 31 09:06:03 2025] [ 1047] 0 1047 27413 3488 2336 1152 0 118784 0 0 unattended-upgr
[Fri Jan 31 09:06:03 2025] [ 1099] 0 1099 1526 480 32 448 0 53248 0 0 agetty
[Fri Jan 31 09:06:03 2025] [ 1140] 0 1140 19526 1504 672 832 0 151552 0 0 nmbd
[Fri Jan 31 09:06:03 2025] [ 1147] 0 1147 22580 2432 800 896 736 176128 0 0 smbd
[Fri Jan 31 09:06:03 2025] [ 1161] 0 1161 21957 1075 787 288 0 143360 0 0 smbd-notifyd
[Fri Jan 31 09:06:03 2025] [ 1162] 0 1162 21959 1107 787 320 0 139264 0 0 smbd-cleanupd
[Fri Jan 31 09:06:03 2025] [ 2014] 0 2014 3005 800 256 544 0 65536 0 -1000 sshd
[Fri Jan 31 09:06:03 2025] [ 22436] 998 22436 77040 1280 192 1088 0 114688 0 0 polkitd
[Fri Jan 31 09:06:03 2025] [ 276974] 0 276974 23068 1478 806 320 352 159744 0 0 smbd-scavenger
[Fri Jan 31 09:06:03 2025] [ 369524] 0 369524 32081 3003 1166 607 1230 200704 0 0 smbd[192.168.1.
[Fri Jan 31 09:06:03 2025] [ 369548] 0 369548 404364 3086 3086 0 0 339968 0 -900 snapd
[Fri Jan 31 09:06:03 2025] [ 369628] 0 369628 29008 1101 256 845 0 241664 0 -250 systemd-journal
[Fri Jan 31 09:06:03 2025] [ 371760] 0 371760 23485 2098 838 651 609 180224 0 0 smbd[192.168.1.
[Fri Jan 31 09:06:03 2025] [ 610543] 0 610543 3363 3273 1801 1472 0 65536 0 -999 atop
[Fri Jan 31 09:06:03 2025] [ 637570] 113 637570 958850 136799 136063 736 0 1777664 0 0 mysqld
[Fri Jan 31 09:06:03 2025] [ 638384] 0 638384 63300 3042 1698 672 672 172032 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 638393] 33 638393 63836 4060 2332 704 1024 200704 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 638394] 33 638394 63787 4033 2241 736 1056 204800 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 638395] 33 638395 63835 4099 2307 736 1056 200704 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 638396] 33 638396 63835 4080 2352 672 1056 204800 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 638397] 33 638397 63834 4202 2442 736 1024 204800 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 638425] 33 638425 9986 3588 3140 448 0 122880 0 0 zmdc.pl
[Fri Jan 31 09:06:03 2025] [ 638452] 0 638452 105568 1280 192 1088 0 163840 0 0 thermald
[Fri Jan 31 09:06:03 2025] [ 638462] 33 638462 275480 144360 141256 1088 2016 1605632 0 0 zmc
[Fri Jan 31 09:06:03 2025] [ 638469] 33 638469 11437 5216 4576 640 0 139264 0 0 /usr/bin/zmcont
[Fri Jan 31 09:06:03 2025] [ 638473] 33 638473 222580 71441 64401 992 6048 1081344 0 0 zmc
[Fri Jan 31 09:06:03 2025] [ 638479] 33 638479 342521 214777 207673 1056 6048 2080768 0 0 zmc
[Fri Jan 31 09:06:03 2025] [ 638489] 33 638489 278195 148513 141409 1056 6048 1572864 0 0 zmc
[Fri Jan 31 09:06:03 2025] [ 638494] 33 638494 14540 8256 7616 640 0 172032 0 0 zmfilter.pl
[Fri Jan 31 09:06:03 2025] [ 638499] 33 638499 15815 9504 8864 640 0 167936 0 0 zmfilter.pl
[Fri Jan 31 09:06:03 2025] [ 638505] 33 638505 15810 9504 8832 672 0 167936 0 0 zmfilter.pl
[Fri Jan 31 09:06:03 2025] [ 638511] 33 638511 14348 8000 7392 608 0 155648 0 0 zmfilter.pl
[Fri Jan 31 09:06:03 2025] [ 638518] 33 638518 13229 7104 6368 736 0 147456 0 0 zmaudit.pl
[Fri Jan 31 09:06:03 2025] [ 638525] 33 638525 9865 3584 2976 608 0 118784 0 0 zmwatch.pl
[Fri Jan 31 09:06:03 2025] [ 638531] 33 638531 13805 7495 6727 768 0 147456 0 0 zmtelemetry.pl
[Fri Jan 31 09:06:03 2025] [ 638537] 33 638537 9795 3488 2912 576 0 126976 0 0 zmstats.pl
[Fri Jan 31 09:06:03 2025] [ 638864] 33 638864 63824 4011 2280 675 1056 204800 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 639273] 33 639273 63837 3887 2127 736 1024 200704 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 639274] 33 639274 63825 4044 2284 736 1024 196608 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 639275] 33 639275 63836 3854 2158 704 992 196608 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 639276] 33 639276 63824 4054 2326 672 1056 204800 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 644568] 33 644568 5374235 5100872 5093768 1056 6048 41791488 0 0 zmc
[Fri Jan 31 09:06:03 2025] [ 648289] 33 648289 63489 2240 1728 512 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648293] 33 648293 63489 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648294] 33 648294 63489 2272 1728 544 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648295] 33 648295 63489 2176 1728 448 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648297] 33 648297 63489 2176 1728 448 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648308] 0 648308 22590 1382 806 544 32 163840 0 0 smbd[192.168.1.
[Fri Jan 31 09:06:03 2025] [ 648310] 0 648310 22590 1318 806 512 0 163840 0 0 smbd[192.168.1.
[Fri Jan 31 09:06:03 2025] [ 648321] 0 648321 2384 739 131 608 0 61440 0 0 cron
[Fri Jan 31 09:06:03 2025] [ 648331] 0 648331 2350 643 131 512 0 61440 0 0 cron
[Fri Jan 31 09:06:03 2025] [ 648333] 33 648333 63489 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648334] 33 648334 63489 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648335] 33 648335 63489 2272 1728 544 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648336] 33 648336 63489 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648337] 33 648337 63489 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648338] 33 648338 63489 2240 1728 512 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648339] 33 648339 63489 2272 1728 544 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648343] 0 648343 2350 707 131 576 0 61440 0 0 cron
[Fri Jan 31 09:06:03 2025] [ 648344] 33 648344 63489 2176 1728 448 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648346] 33 648346 63489 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648347] 33 648347 63489 2176 1728 448 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648348] 33 648348 63489 2176 1728 448 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648352] 33 648352 63489 2240 1728 512 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648357] 33 648357 63489 2176 1728 448 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648362] 33 648362 63489 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648363] 33 648363 63484 2272 1728 544 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648364] 33 648364 63489 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648368] 0 648368 22580 1158 806 352 0 143360 0 0 smbd[192.168.1.
[Fri Jan 31 09:06:03 2025] [ 648369] 33 648369 63484 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648371] 0 648371 22580 1158 806 352 0 143360 0 0 smbd[192.168.1.
[Fri Jan 31 09:06:03 2025] [ 648373] 33 648373 63484 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648374] 33 648374 63484 2240 1728 512 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648375] 33 648375 63484 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648376] 33 648376 63484 2208 1728 480 0 163840 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648380] 0 648380 63480 2208 1728 480 0 155648 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648381] 0 648381 22580 1158 806 352 0 143360 0 0 smbd[192.168.1.
[Fri Jan 31 09:06:03 2025] [ 648382] 0 648382 22580 1126 806 320 0 143360 0 0 smbd[192.168.1.
[Fri Jan 31 09:06:03 2025] [ 648383] 0 648383 3005 603 283 320 0 57344 0 0 sshd
[Fri Jan 31 09:06:03 2025] [ 648384] 0 648384 22580 1126 806 320 0 143360 0 0 smbd[192.168.1.
[Fri Jan 31 09:06:03 2025] [ 648385] 0 648385 1791 451 67 384 0 57344 0 0 cron
[Fri Jan 31 09:06:03 2025] [ 648386] 0 648386 3005 539 283 256 0 57344 0 0 sshd
[Fri Jan 31 09:06:03 2025] [ 648387] 0 648387 63420 2144 1728 416 0 151552 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648388] 0 648388 63420 2144 1728 416 0 151552 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648389] 0 648389 63420 2208 1728 480 0 151552 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648390] 0 648390 63420 2176 1728 448 0 151552 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648391] 0 648391 63420 2176 1728 448 0 151552 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648392] 0 648392 63420 2176 1728 448 0 151552 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648393] 0 648393 63420 2176 1728 448 0 151552 0 0 apache2
[Fri Jan 31 09:06:03 2025] [ 648394] 0 648394 22580 1094 806 288 0 143360 0 0 smbd[192.168.1.
[Fri Jan 31 09:06:03 2025] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=zoneminder.service,mems_allowed=0,global_oom,task_memcg=/system.slice/zoneminder.service,task=zmc,pid=644568,uid=33
[Fri Jan 31 09:06:03 2025] Out of memory: Killed process 644568 (zmc) total-vm:21496940kB, anon-rss:20375072kB, file-rss:4224kB, shmem-rss:24192kB, UID:33 pgtables:40812kB oom_score_adj:0
