Page 1 of 1
Best practice / optimizing
Posted: Sat Oct 05, 2024 2:53 am
by blaczero
Is there a doc or something that makes it easy to understand what I can change to optimize the system?
I just got a Minisforum 773 with 64gig of ram, and I'm already down to 300mb free and .83 load average on the CPU.
I have changed the cameras to 10FPS already. Is it just resolution and image buffer size now?
Re: Best practice / optomizing
Posted: Sat Oct 05, 2024 2:22 pm
by Andyrh
How many monitors?
What is reporting 300 MB of RAM free?
I have 16GB of RAM and 14 monitors. 364MB free and 11,896MB available. So, I am not close to being out of RAM.
free -m
total used free shared buff/cache available
Mem: 15896 3273 364 389 12259 11896
Swap: 4095 1367 2728
Posted: Sun Oct 06, 2024 5:55 pm
by blaczero
Andyrh wrote: ↑Sat Oct 05, 2024 2:22 pm
How many monitors?
free -m
3 cameras right now, top is reporting 300mb free, no swap used. I am about 80% utilization (1 CPU core).
I figured I was setting something wrong, that's why I asked here.
Posted: Sun Oct 06, 2024 7:48 pm
by Andyrh
It is not a bad question.
top reports only the "free" number. free reports all of the numbers.
Posted: Sun Oct 06, 2024 8:29 pm
by blaczero
free reports this
Mem: 63507688 5467172 897008 102244 57977016 58040516
Swap: 8388604 256 8388348
So as far as CPU usage, am I high?
- zm-resource1.png (26.69 KiB) Viewed 2999 times
Also, I'm at over 1.5TB used in the last 3 days, I've shortened the events to 60 seconds, where else do I optimize that? Can I choose how sensitive the event capture is?
Re: Best practice / optimizing
Posted: Mon Oct 07, 2024 12:38 pm
by Andyrh
free is showing a large cache. You have plenty of RAM.
Each zone sensitivity can be set. There are several threads on adjusting zones. It can take a long time to get the first one right, after that the others will be easier. You will have learned a lot. One tip is to use pixels instead of percentage. That will allow for finer control.
Frequently extra disk space is used if you are saving jpegs. I have "Save JPEGs" set to disabled. I enable them when adjusting a zone so I can see what tripped the detection. I am getting around 50 days from 4TB when all 6 monitors are running. 1 is currently down.
I also have "Video Writer" set to Camera Passthrough to save CPU time.
Hard to tell from the screen shot how busy the system really is. I have 12 threads and run in the ~25% range. I prefer nmon for this data, a throwback to my AIX days. You can see ZM prefers the physical cores over the virtual cores, but it will make them all busy if needed. Right now I have 5 monitors doing modect, 5 record and the rest are monitor or down. The frame rate is 10FPS or lower.
- Screenshot 2024-10-07 072603.png (44.77 KiB) Viewed 2963 times
