ReferenceError spanTime
Re: ReferenceError spanTime
Do you need the docs? They are available online... I'd just remove them.
Anna.N
Post by Anna.N »
Anna.N wrote: Mon Sep 30, 2024 9:20 pm :D 1.37.64 without any error (so far)
:| when changing the scale in replay only actual and auto work, all others produce the following error:
897593	ERR	ReferenceError: assignment to undeclared variable h	zm/cache/skins_classic_views_js_event-base-1727715366.js	321
IgorA100
Post by IgorA100 »
Anna.N wrote: Thu Oct 03, 2024 7:01 am the following error:
Fix: https://github.com/ZoneMinder/zoneminder/pull/4166
Bluemax
Post by Bluemax »
iconnor wrote: Wed Oct 02, 2024 12:58 pm Do you need the docs? They are available online... I'd just remove them.
Removing the docs package as dependency making them two separate packages might be a good solution.
