180 degree camera - non standard resolutions
AnotherBrian
Post by AnotherBrian »
Example 180 degree camera has resolution 5120x1440.
Will zoneminder support this cam?
Put another way:
When provisioning a cam, under source, zoneminder provides
3 fields for "Capture Resolution (pixels)" where first and second fields are numbers and 3rd is pull down menu of standard formats.
So I'm guessing one configures 5120x1440 and zoneminder DOES NOT require configuration of the 3rd pull down.
Or then again, maybe just standard resolutions are supported.
Specific camera is HikVision DS-2CD2T87G2P
Thanks in advance for reply!
Re: 180 degree camera - non standard resolutions
It will work just fine, just enter that resolution for custom.
