Installation routine crashes
Posted: Tue Apr 27, 2004 10:14 am
Hi everybody,
first I would like to say that ZoneMinder and also the LiveCD is a really great product and I like it!!!
So I tried to install the new LiveCD, V.1.19.1. Everything works fine (I also had to add the boot parametres: livecd noscsi), I created two partitions, a large 30GB root fs (ext3) and a smaller swap partition (3GB ext3).
After that, I started the KDE installation wizard. At about 12 % the installation crashes and the system hangs up. The routine try to do something with "urpmi"...I think it tries to extract the packages.
I tried it three more times, but every time same result.
I can´t check any log file or syslogd because the machine is REALLY crashed... Hardware detection in bootup process works fine and no error occurs.
Maybe you know a problem with <urpmi> or can give me a hint?
Hardware: Fujitsu Siemens W600, P3 4Ghz, 512MB Ram, 80GB HDD, GrandTec X-Guard 4-port
Thanks in advance,
Ralph
Thanks in advance,
Ralph
