Network triggering examples?
Posted: Sat Aug 24, 2024 9:55 pm
I am wanting to do some triggering from other devices on my network. Zoneminder is on a PC and I want to send triggers from raspberry pi or esp32 or the like. When I looked a the wiki it said to enable triggers:
Thing is I didn't find that option. Guessing it has moved on the newer version? I did find Opt_Triggers under system. Is that the same thing?
The wiki is a bit light on examples IMHO. Where would I find more examples? I did a bit of googling - maybe I am not using the correct terms...
