after updating to 1.36.34 getting undefined - setConstant() in file ?view=log component web_js. This is with both Ubuntu 20.04 and 22.04. Non increasing dts is spamming the log about 15 entries per second. That is not new, been doing this for quite a while. Set the log levels to error on all, seems to have fixed the Ubuntu 22.04 system, but not the 20.04 system..
The 32bit color 3840x2160 cameras are showing red on the Ubuntu 22.04 system in the web GUI but event capture (modetect) is working. Stopping, clearing the log, and restarting seems to resolve the issue, but it almost immediately comes back. The set constant message appears to be cosmetic, since the thumbnails are not showing in the console.
Just a guess but it looks like there is a java error.
Re: after updating to 1.36.34 getting undefined - setConstant()
Please check the javascript console and cutnpaste the error here. We need more info.
maybe this will help
- ZMjavaerror.txt
- (5.03 KiB) Downloaded 85 times
Pretty weird. Never seen those before. I'm suspecting some plugin or addon is at fault.
I have a 438 mb tar file of a 4 gb debug log but the website states the file is to large. This server only does Zoneminder it runs Ubuntu 22.04. it did not matter if ad blocker is disabled or not. I updated java to the most recent version. Java reports openjdk version "11.0.24" 2024-07-16, OpenJDK Runtime Environment (build 11.0.24+8-post-Ubuntu-1ubuntu320.04), OpenJDK 64-Bit Server VM (build 11.0.24+8-post-Ubuntu-1ubuntu320.04, mixed mode, sharing) I assume open JDK is the zoneminder preference. It did not make a difference. I suspect if this is a problem, others will report the same. It does appear motion capture is working, thus as long as capture is working It appears to be a cosmetic error. Right now all of the hi def camera's are reporting as not running, which I know is not true because motion detection is working and creating events. The browser is Firefox v 129.0.2 64 bit. I don't have another browser installed on this machine.
