ZmEventNotification: how to use a python virtual environment instead of system python
bzzmid
Post by bzzmid »
Hello to all,
I've googled around but I've not found anything relevant: in case it was right beneath my eyes, I'm sorry.
I'd like to install zmeventnotification in such a way it can use a custom python virtual environment (with all the packets ZM ES needs) instead of the default system-wide installation of python.
I've noticed that the first two lines of install.sh are:
PYTHON=${PYTHON:-python3}
PIP=${PIP:-pip3}
I was wondering whether it would be enough to hard edit the two variables to the path to a custom virtual environment. Is there anything else that should be edited and I'm not aware of?
Thank you in advance
volfan6415
Re: ZmEventNotification: how to use a python virtual environment instead of system python
Post by volfan6415 »
Any updates here? I had a working eventnotification server and upgraded to 24.04 and now python is complaining about needing a virtual environment to get the machine learning hooks setup. What is the proper path forward?
burger
Post by burger »
I ran into this when installing on Debian 12 / Devuan 5. I just set it to --break-system-packages for the time being. It's not critical enough for me to troubleshoot further. See: https://wiki.zoneminder.com/ZMES#This_e ... ystem-wide,
fastest way to test streams:
