cant logout and access videos and stuff like that.
Shadow
Post by Shadow »
I have an old server where zoneminder works great, Now I got a newer and installed ubuntu and installed zoneminder. Even tried compiling it, but still got the same problem.
I cant logout, cant change server status(start and stop). Cant even go in and add a new storage. Cant access and remove videos that got recorded.
tried checking so I have about the same packages.
What is common with there stuff? I s there any specific things I should look for?
Cant find any errors.
Thanks in advance,
Shadow
Re: cant logout and access videos and stuff like that.
You may have found an incorrect how to.
Here's a good one https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.36.x
just change the repo to master if you really want 1.37 and it ought to work.
Shadow
Post by Shadow »
I tried that guide, everything works exept all these white windows. like when you click log out or when you goes to option and choose storage and tries opening like default storage or like clicking "add new storage" no white window pops up in zoneminder.
it's a new installed ubuntu 22.04,
php8.2-fpm useing apache2, tried useing nginx too, but it doesnt work neither
You're using 1.37?
What are you installing on - bare metal or ?
Logs?
Shadow
Post by Shadow »
6.5.0-28-generic #29~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Apr 4 14:39:20 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
HP Elitedesk med i5-7500 och 16GB DDR4, 256GB
cant access any logs in zoneminder.
/var/log/zm/zms.log is empty
/var/log/zm/zmwatch.log is empty
/var/log/zm/zmupdate.log is empty
/var/zm/zmpkg.log
2024-05-04 00:00:02.060131 zmpkg[15079].INF [main:332] [Sanity checking States table...]
2024-05-04 00:00:02.087217 zmpkg[15079].INF [main:111] [Command: logrot]
/var/log/zm/zmtelemetry.log is empty
/var/log/zm/error.log is empty
/var/log/zm/ web_js.log is empty
/var/log/zm/apache-error.log is empty
/var/log/zmdc.log is empty
/varlog/zm/web_php.log
2024-05-04 17:37:46 CEST.756772 web_php[19950].INF [192.168.0.100] [Login successful for user "admin"] at /usr/share/zoneminder/www/includes/auth.php line 476
I tried install 1.36.12 1.36.33 and the 1.37.59 (1.37.59 works on my old computer)
/var/log/zm/error.log should probably be owner&group www-data, or whatever it is on the working machine. True? or?
Shadow
Post by Shadow »
it is www-data.www-data and it is working exept I cant check logs. logout or change storage place cuase it doesn't create the white windows. Can even go in and check the videos, it says it recorded 38.
What it is that create the white windows, php? javascript?
Dunno, sorry. When you install, are you doing so as super user? If not, please try with sudo su.
That's how Ive always done it, but seems to not be mentioned, so it may not matter, but maybe it does?
Shadow
Post by Shadow »
Its the way I do it.
You know this has to be something stupid simple, but I'm out of ideas.
Unless you want to clone the working one, to see if maybe there's some hardware problem. :(
