Page 1 of 1
Fix STOPPED state after reboot
Posted: Mon Apr 01, 2024 3:09 pm
by TruckerDave
It took me quite a bit of searching to find the very simple answer to the question ...
My ZoneMinder loads in a STOPPED state.
How do I make ZoneMinder load in a RUNNING state after a power outage or reboot?
Open a terminal and run:
Yes. It's that simple. So, simple it's probably a given to seasoned Linux users.
Re: Fix STOPPED state after reboot
Posted: Mon Apr 01, 2024 5:24 pm
by mikb
TruckerDave wrote: ↑Mon Apr 01, 2024 3:09 pm
Seasoned Linux users avoid systemd ...
so might well get caught on that when forced to use the thing.
(Slackware and proud!)
Posted: Tue Apr 02, 2024 8:02 am
by dougmccrary
However, if you use the recommended script, that's in there.
Posted: Tue Apr 02, 2024 5:18 pm
by mikb
dougmccrary wrote: ↑Tue Apr 02, 2024 8:02 am
One of the recurring problems seems to be that there are definitive, tested and we-know-these-work instructions.
Then, there are other sites with out of date, incomplete instructions.
And finally, there are AI systems chomping through all that and creating new approximate instructions, for clicks and advertising revenue.
When people Google for "How do I fix X with ZoneMinder" it's a coin toss which they find first ...
Posted: Wed Apr 03, 2024 7:19 am
by dougmccrary
You're right.
We probably ought to have the "right" instructions pinned somewhere, so when the question comes up we can just tell them where to look.
OR, maybe a new "New to Zoneminder? Install tips." or similar would be where to put it.
Posted: Wed Apr 03, 2024 5:37 pm
by mikb
dougmccrary wrote: ↑Wed Apr 03, 2024 7:19 am
You're right.
That is the most practical answer ... my thoughts were more along the line of hunt down all the wrong ones and nuke them
The real problem is getting the RIGHT instructions to appear in Google/etc. ahead of all the SEO-optimized wrong ones.
Posted: Thu Apr 04, 2024 4:03 am
by dougmccrary
This
Unfortunately there are a few (now or always) wrong instructions on personal sites too.
