[SOLVED] command exited with status: 1
GadgetChris
Post by GadgetChris »
I just upgraded to docker version 1.36.33 from 1.36.32 to see if this fixed my issue, but to no avail.
I have a folder:
root@023c028759ee:/# ls -l /var/www/scripts/
total 8
-rwxrwxr-x 1 1000 1000 118 Mar 12 22:48 trigger.sh
-rwxrwxr-x 1 1000 1000  32 Mar 12 23:08 zm-approach
-rw-rw-r-- 1 1000 1000   0 Mar 11 00:37 zm-package
And I can manually run successfully:
root@e59f8d6fac75:/# zmfilter.pl --filter "trigger approach"
03/12/24 23:08:37.748207 zmfilter[822468].INF [main:179] [Scanning for events using filter 'trigger approach']
03/12/24 23:08:37.873674 zmfilter[822468].INF [main:1061] [Executing '/var/www/scripts/trigger.sh zm-approach /data/events/2/2024-03-11/20345']
03/12/24 23:08:37.880845 zmfilter[822468].INF [main:1061] [Executing '/var/www/scripts/trigger.sh zm-approach /data/events/2/2024-03-11/20347']
The trigger script will just put the event data in a file within the script directory:
root@023c028759ee:/# cat /var/www/scripts/trigger.sh
#!/bin/bash
#--- create a trigger for host processing
#set -x
#source ~/.bash_trace
cd /var/www/scripts
echo $2 > $1
In my filter I define for action the command execution:
Execute command on all matches[b]:[/b]
in the logs I see:
3/12/24, 11:58:43 PM EDT	zmfilter_6		529	ERR	Command '/var/www/scripts/trigger.sh zm-package /data/events/2/2024-03-12/20575' exited with status: 1
What does this error mean?
And how can I succeed in getting the file created...
( On the host I have scripts waiting to further take action on the creation of this file...)
Thank you, Chris
p.s. Why can I not enter a colon in the text?
zm-v1.36.33 in docker @ Ubuntu 22.04.4.LTS
Re: command exited with status: 1
Can www-data use those? Looks like they're root.
Your script has to get return a value of 0 for success. You don't explicitly set a return value, so it will be whatever the return value of the last line is. In the case echo $2 > $1?
GadgetChris
iconnor wrote: Wed Mar 13, 2024 1:19 pm Your script has to get return a value of 0 for success. You don't explicitly set a return value, so it will be whatever the return value of the last line is.
Thank you, that makes sense.
I'm still not sure it's working, due to filled up logs. Will open a separate thread for that.
GadgetChris
Re: [SOLVED] command exited with status: 1
While running in a docker container, there is no syslog logs to check for permission failures - that I have found thus far.
After explicitly setting the owner to www-data the trigger started to fire:
root@023c028759ee:/# chown www-data /var/www/scripts/*
total 12
-rwxrwxr-x 1 www-data 1000 125 Mar 13 10:50 trigger.sh
-rwxrwxr-x 1 www-data 1000  32 Mar 12 23:08 zm-approach
-rw-rw-r-- 1 www-data 1000  32 Mar 16 09:48 zm-package
Thank you for your help.
:D
