Linked Monitors create segmentaion fault
Burtski
Post by Burtski »
Following up on a previous post:
When I have my high resolution monitors linked to their low resolution counterparts, they generate Segmentation Faults in the log files and nothing gets recorded.
When I Unlink these monitors and set them to motion detection, they appear to work as intended.
Motion detection on the high resolution monitors eats up a lot of horse power.
I would also like any low resolution monitors to trigger all high resolution monitors.
Side note:
Would it be possible to create a group with all my low resolution monitors in it and trigger the high resolution monitors from the GROUP instead of individual monitors. just less messy when there are a lot of monitors to trigger from
Re: Linked Monitors create segmentaion fault
There was recently a potential segfault... but it has since been fixed. So make sure you are up to date.
No you can't link to a group at this time. You want to fund it, I could make it happen, although I think it is already too complicate this stuff.
Burtski
Post by Burtski »
Currently running:
Version: 1.37.55~20240305163649-focal
IgorA100
Post by IgorA100 »
Try using a second thread to analyze the motion.
It somehow worked for me (albeit with errors in the log) on some high-resolution cameras.
You can use Onvif detection, it also seems to work.
Making two groups is not a good idea, it's a lot of chaos.
