Page 1 of 1
1.37.53 cannot add or change monitor
Posted: Fri Feb 23, 2024 11:17 am
by ArchanfelHUN
Hello!
Recently i just updated to 1.37.53.
Now i cant change anything in any monitor nor can add a new one. The error is this every time:
SQL-ERR '00000 ', statement was 'UPDATE `Monitors` SET `Id`=?, `Name`=?, `Deleted`=?, `Notes`=?, `ServerId`=?, `StorageId`=?, `ManufacturerId`=?, `ModelId`=?, `Type`=?, `Capturing`=?, `Analysing`=?, `Recording`=?, `RecordingSource`=?, `AnalysisSource`=?, `AnalysisImage`=?, `Enabled`=?, `Decoding`=?, `RTSP2WebEnabled`=?, `RTSP2WebType`=?, `JanusEnabled`=?, `JanusAudioEnabled`=?, `Janus_Profile_Override`=?, `Janus_Use_RTSP_Restream`=?, `Janus_RTSP_User`=?, `Janus_RTSP_Session_Timeout`=?, `LinkedMonitors`=?, `Triggers`=?, `EventStartCommand`=?, `EventEndCommand`=?, `ONVIF_URL`=?, `ONVIF_Username`=?, `ONVIF_Password`=?, `ONVIF_Options`=?, `ONVIF_Alarm_Text`=?, `ONVIF_Event_Listener`=?, `use_Amcrest_API`=?, `Device`=?, `Channel`=?, `Format`=?, `V4LMultiBuffer`=?, `V4LCapturesPerFrame`=?, `Protocol`=?, `Method`=?, `Host`=?, `Port`=?, `SubPath`=?, `Path`=?, `SecondPath`=?, `Options`=?, `User`=?, `Pass`=?, `Width`=?, `Height`=?, `Colours`=?, `Palette`=?, `Orientation`=?, `Deinterlacing`=?, `Decoder`=?, `DecoderHWAccelName`=?, `DecoderHWAccelDevice`=?, `SaveJPEGs`=?, `VideoWriter`=?, `OutputCodec`=?, `Encoder`=?, `OutputContainer`=?, `EncoderParameters`=?, `RecordAudio`=?, `RTSPDescribe`=?, `Brightness`=?, `Contrast`=?, `Hue`=?, `Colour`=?, `EventPrefix`=?, `LabelFormat`=?, `LabelX`=?, `LabelY`=?, `LabelSize`=?, `ImageBufferCount`=?, `MaxImageBufferCount`=?, `WarmupCount`=?, `PreEventCount`=?, `PostEventCount`=?, `StreamReplayBuffer`=?, `AlarmFrameCount`=?, `SectionLength`=?, `SectionLengthWarn`=?, `MinSectionLength`=?, `EventStartMode`=?, `EventCloseMode`=?, `FrameSkip`=?, `MotionFrameSkip`=?, `AnalysisFPSLimit`=?, `AnalysisUpdateDelay`=?, `MaxFPS`=?, `AlarmMaxFPS`=?, `FPSReportInterval`=?, `RefBlendPerc`=?, `AlarmRefBlendPerc`=?, `Controllable`=?, `ControlId`=?, `ControlDevice`=?, `ControlAddress`=?, `AutoStopTimeout`=?, `TrackMotion`=?, `TrackDelay`=?, `ReturnLocation`=?, `ReturnDelay`=?, `ModectDuringPTZ`=?, `DefaultRate`=?, `DefaultScale`=?, `SignalCheckPoints`=?, `SignalCheckColour`=?, `WebColour`=?, `Exif`=?, `Sequence`=?, `ZoneCount`=?, `Refresh`=?, `DefaultCodec`=?, `Latitude`=?, `Longitude`=?, `RTSPServer`=?, `RTSPStreamName`=?, `SOAP_wsa_compl`=?, `Importance`=?, `MQTT_Enabled`=?, `MQTT_Subscriptions`=? WHERE Id=?'
It was worked fine with 1.37.45.
Please look into it.
Thanks!
Re: 1.37.53 cannot add or change monitor
Posted: Fri Feb 23, 2024 12:40 pm
by ArchanfelHUN
1.37.51 is okay, 1.37.53 is not.
