Page 1 of 1
Infrared reflective tape
Posted: Sun Jan 21, 2024 5:19 pm
by BiloxiGeek
Anybody got a good suggestion for some reflective tape that will show up nice and bright when a camera is in night mode with the infrared LEDs shining?
I got a camera in my workshop that has a view of the deadbolt. If the lights are on I can barely make out whether the deadbolt is locked or not. If the lights are off there's no way to see that. I was thinking some tape on the handle for the deadbolt would make it fairly easy to see if I can find a reflective tape that will show up bright and shiny in the LEDs IR light.
Re: Infrared reflective tape
Posted: Sun Jan 21, 2024 6:00 pm
by mikb
BiloxiGeek wrote: ↑Sun Jan 21, 2024 5:19 pm
Sounds like a good plan.
I would have thought any "retroreflector" style of tape/covering would work for this -- IR or visible. The sort used on *genuine* high-vis jackets as a silver trim. These are designed to always return light back in the direction it came. Unlike a mirror, which bounces it off at an equal-but-opposite angle!
Investigate your local pound-shop/dollar-store for high-vis dog collars. These are sometimes all I can see of passing pets at the bottom of my drive: Out of range of my IR light for the dog, but the collar shines real good!
Note: There are FAKE "reflective" tapes/clothing that are just grey/silver. These are useless in all ways
Posted: Tue Jan 23, 2024 10:51 pm
by BiloxiGeek
I mistakingly got some lens tape in the auto parts section at Walmart. That didn't do a thing, it's made to cover a broken tail light. Good thing it didn't cost much, I wasn't paying attention and thought it was reflective tape.
Gonna look again next time I'm out in the retail world.
Posted: Wed Jan 24, 2024 6:29 pm
by mikb
Take a bright torch (flashlight) and check it -- look down the axis of the torchlight and see if the light is coming back at you
[Edit: Translation to UK->US
Posted: Sat Jan 27, 2024 7:57 pm
by BiloxiGeek
Paid attention this time and got proper reflective tape. A strip along the long axis of the handle shows up nicely when the IR LEDs wars lit up. Gonna cut a thinner strip so it'll be even more obvious.
Posted: Tue Jan 30, 2024 2:45 pm
by alabamatoy
look up "conspicuity tape" on Amazon. My cameras light it up like a flare at night, but its no visible without the IR light.
Posted: Tue Jan 30, 2024 2:47 pm
by alabamatoy
This is what I got, works extremely well with the camera night vision:
https://www.amazon.com/dp/B07V3W45WL?re ... tails&th=1 Also reflects visible light very well so you can light it up with a flashlight.
