firewall config
Danzi
firewall config
Post by Danzi »
ZM v 1.34.26; Ubuntu 18.04
I have activated the firewall in Ubuntu and installed UFW. the UFW gui says IN blocked; OUT not blocked.
Therefore cannot access ZM with a web browser from other then the server PC that ZM resides on at 192.168.1.131/zm/index.php.
what ports IN do I need to open?
I've done INET searches and anything I found does not allow access.
Many thanks
Dan
militarybasalt
Re: firewall config
Post by militarybasalt »
To access ZoneMinder (ZMgeometry dash online) from a web browser on a different PC, you need to open the necessary ports in your firewall. By default, ZoneMinder uses port 80 for HTTP and port 443 for HTTPS. However, since you mentioned that the UFW GUI shows "IN blocked," it seems like the firewall is blocking incoming connections.
