ZM 1.37.47 Event splits when monitor is linked.
Posted: Wed Dec 27, 2023 9:00 pm
With ZM 1.37.47 I observed that an event recorded by the sub-stream and which is 16 seconds long is split into two events on the linked main stream monitor.
The pre-event buffer and post-event buffer settings for both streams are set identically to 60 frames. The camera is set to Main and Sub-Stream to 15 fps.
The same event was also captured by ZM 1.36.33 with identical settings and by the same camera. The linked main stream was not split up.
Best regards
Detlef Paschke
Ereignis-ID 173
Ereignisname Event-173
Monitor-ID 1
Monitorname Annke_C500-SD
Grund Motion:Hauptzone,Hof gesamt
Bemerkungen Motion: Hauptzone, Hof gesamt
Start Time 27.12.23, 21:00:11 MEZ
End Time 27.12.23, 21:00:27 MEZ
Dauer 00:00:16
Bilder 185
Alarmbilder 6
Gesamtwertung 8
Mittlere Wertung 1
Maximale Wertung 1
Resolution 640x360
DiskSpace 173.49kB
Storage Default
Path /var/cache/zoneminder/events/1/2023-12-27/173
Archivierte Ja
Emailed Nein
Ereignis-ID 174
Ereignisname Event-174
Monitor-ID 2
Monitorname Annke_C500-HD
Grund Linked
Bemerkungen
Start Time 27.12.23, 21:00:10 MEZ
End Time 27.12.23, 21:00:21 MEZ
Dauer 00:00:11
Bilder 169
Alarmbilder 0
Gesamtwertung 40
Mittlere Wertung 0
Maximale Wertung 20
Resolution 3072x1728
DiskSpace 1.65MB
Storage Default
Path /var/cache/zoneminder/events/2/2023-12-27/174
Archivierte Ja
Emailed Nein
Ereignis-ID 175
Ereignisname Event-175
Monitor-ID 2
Grund Linked
Bemerkungen
Start Time 27.12.23, 21:00:18 MEZ
End Time 27.12.23, 21:00:28 MEZ
Dauer 00:00:10
Bilder 152
Alarmbilder 0
Gesamtwertung 20
Mittlere Wertung 0
Maximale Wertung 20
DiskSpace 1.55MB
Storage Default
Path /var/cache/zoneminder/events/2/2023-12-27/175
Archivierte Ja
Emailed Nein
Ereignis-ID 5992
Ereignisname Event-5992
Monitor-ID 1
Grund Motion
Bemerkungen
Dauer 16.32
Bilder 185
Alarmbilder 30
Gesamtwertung 30
Mittlere Wertung 1
Maximale Wertung 1
DiskSpace 182.90kB
Storage Default
Archivierte Ja
Emailed Nein
Ereignis-ID 5993
Ereignisname Event-5993
Monitor-ID 2
Grund Linked
Bemerkungen
End Time 27.12.23, 21:00:26 MEZ
Dauer 15.79
Bilder 238
Alarmbilder 27
Gesamtwertung 27
Mittlere Wertung 1
Maximale Wertung 1
DiskSpace 2.74MB
Storage Default
Archivierte Ja
Emailed Nein
Detlef Paschke
