ZM 1.37.47 Event splits when monitor is linked.
Detlef Paschke
Post by Detlef Paschke »
With ZM 1.37.47 I observed that an event recorded by the sub-stream and which is 16 seconds long is split into two events on the linked main stream monitor.
The pre-event buffer and post-event buffer settings for both streams are set identically to 60 frames. The camera is set to Main and Sub-Stream to 15 fps.
Ereignis-ID		173
Ereignisname		Event-173
Monitor-ID		1
Monitorname		Annke_C500-SD
Grund			Motion:Hauptzone,Hof gesamt
Bemerkungen		Motion: Hauptzone, Hof gesamt
Start Time		27.12.23, 21:00:11 MEZ
End Time		27.12.23, 21:00:27 MEZ
Dauer			00:00:16
Bilder			185
Alarmbilder		6
Gesamtwertung		8
Mittlere Wertung	1
Maximale Wertung	1
Resolution		640x360
DiskSpace		173.49kB
Storage			Default
Path			/var/cache/zoneminder/events/1/2023-12-27/173
Archivierte		Ja
Emailed			Nein
Ereignis-ID		174
Ereignisname		Event-174
Monitor-ID		2
Monitorname		Annke_C500-HD
Grund			Linked
Bemerkungen
Start Time		27.12.23, 21:00:10 MEZ
End Time		27.12.23, 21:00:21 MEZ
Dauer			00:00:11
Bilder			169
Alarmbilder		0
Gesamtwertung		40
Mittlere Wertung	0
Maximale Wertung	20
Resolution		3072x1728
DiskSpace		1.65MB
Storage			Default
Path			/var/cache/zoneminder/events/2/2023-12-27/174
Archivierte		Ja
Emailed			Nein
Ereignis-ID		175
Ereignisname		Event-175
Monitor-ID		2
Grund			Linked
Bemerkungen
Start Time		27.12.23, 21:00:18 MEZ
End Time		27.12.23, 21:00:28 MEZ
Dauer			00:00:10
Bilder			152
Alarmbilder		0
Gesamtwertung		20
Mittlere Wertung	0
Maximale Wertung	20
DiskSpace		1.55MB
Storage			Default
Path			/var/cache/zoneminder/events/2/2023-12-27/175
Archivierte		Ja
Emailed			Nein
The same event was also captured by ZM 1.36.33 with identical settings and by the same camera. The linked main stream was not split up.
Ereignis-ID		5992
Ereignisname		Event-5992
Monitor-ID		1
Grund			Motion
Bemerkungen
Dauer			16.32
Bilder			185
Alarmbilder		30
Gesamtwertung		30
Mittlere Wertung	1
Maximale Wertung	1
DiskSpace		182.90kB
Storage			Default
Archivierte		Ja
Emailed			Nein
Ereignis-ID		5993
Ereignisname		Event-5993
Monitor-ID		2
Grund			Linked
Bemerkungen
End Time		27.12.23, 21:00:26 MEZ
Dauer			15.79
Bilder			238
Alarmbilder		27
Gesamtwertung		27
Mittlere Wertung	1
Maximale Wertung	1
DiskSpace		2.74MB
Storage			Default
Archivierte		Ja
Emailed			Nein
Best regards
Detlef Paschke
