Filling up disk
spd2612
Filling up disk
Post by spd2612 »
I only use zoneminder to monitor but it keeps filling up my disk
Its on Ubunto 22.04
How can I clear the over 1 million logs I show in the log viewer
Re: Filling up disk
Options->
Screenshot 2023-12-15 at 13-09-15 ZM - Options.png (35.67 KiB) Viewed 26399 times
should do it.
spd2612
Re: Filling up disk
Post by spd2612 »
I truncated the logs from phpmyadmin but the disk still has not changed there was over 1 mill in the database
This has been running trouble free for over a year
Re: Filling up disk
Did you check the trash?
spd2612
Re: Filling up disk
Post by spd2612 »
Yup I did
I extended that vm’s disk space so I will be fine for now
I will watch it to make sure the issue dont continue
And I shut off logging
Thanks for the reply
spd2612
Re: Filling up disk
Post by spd2612 »
Where are all of zoneminders files at My drive is still growing by a gig a day
Cameras are only set to monitor and logging is turned off
