video generation error
Andrew85
Post by Andrew85 »
I have by some days this error in the logs
Video generation '/usr/bin/zmvideo.pl -e 45113 -r 1 -s 0 -f mp4' failed with status: 9
screenshot here
https://postimg.cc/YhZq7bPw
what should I do?
I have done recently some ubuntu updates
I have kubuntu 22.04 and zoneminder version 1.36.33
many thanks in advance
Andrew
Andrew85
Re: video generation error
Post by Andrew85 »
I forgot to say which version is FFmpeg, it is version 4.4.2
any idea what to do?
thanks
Try running it on the command line, perhaps there will be better output.
sudo /usr/bin/zmvideo.pl -e 45113 -r 1 -s 0 -f mp4
Andrew85
Post by Andrew85 »
here the error
31/10/2023 21:37:12.814967 zmvideo[329671].INF [ZoneMinder::Event:302] [Creating video file Event-45113-r1-s1.mp4 for event 45113]
Use of uninitialized value in division (/) at /usr/share/perl5/ZoneMinder/Event.pm line 304.
Illegal division by zero at /usr/share/perl5/ZoneMinder/Event.pm line 304.
here the 304 line of the file
my $frame_rate = sprintf('%.2f', $self->{Frames}/$self->{FullLength});
my understanding is that $self is 0 so the division is not valid?
can someone check that line?
thanks
I don't know how old you zmvideo.pl is... but current 1.36.33 has no line 304. I don't know if our current version works as not many people use it, but it's a good place to start.
mikb
Post by mikb »
Andrew85 wrote: Tue Oct 31, 2023 8:38 pm Illegal division by zero at /usr/share/perl5/ZoneMinder/Event.pm line 304.
I suspect $self isn't zero, but the member {FullLength} is zero. It warns about something be un-initialised, which would be my first instinct to check. Uninitialised things often, but not always, end up at zero until set otherwise ;)
Andrew85
Post by Andrew85 »
ok I have searched in the hard disk that event
there are files
then I looked at the event and I fount that file with a name like 0000capture is missing and so only one frame is present
in the directory there are like 15 frames (jpg files)
so I think I can just delete this event and live without problems :) also because only a shadow is visible in that event
probably an error in the file system has not saved the 0000capture file ?
thanks everyone for the attention
regards
Andrew
There should not exist a 0000. File. Counting begins at 1
