[SOLVED] Montage view blank screen
zemerdon
Post by zemerdon »
So everything going well.
Just added another camera and when i go to the 8hour button on the montage view it just shows a white screen with the address in the address bar.
However if i use the 1hour button it works fine. Is there a way to diagnose whats going wrong please? Nothing shows up in the logs.
I have tried several different browsers and computers to see if it was client side. Any ideas/help would be much appreciated.
I'm wondering if i need to allocate more memory or increase the requests for sql or something to do with apache perhaps.
UPDATE 5MINS LATER
As suggested from a previous post, edited apache2, php.ini and increased memory_limit to 5128M and works perfectly again. Thank you :)
