Page 1 of 1
Search problem
Posted: Tue Apr 13, 2004 8:55 am
by loop
Nice job regarding web site etc. But I cannot make search working. It doesn't find andy matches. For example if I type a seach term "memory" or "*memory*" it finds 0 hits.
Am I doing something wrong ?
Best regards,
Darko
Posted: Tue Apr 13, 2004 9:24 am
by zoneminder
I suspect this is to do with the posts etc all having had to be imported from the old forums and so no indexing of their content has been done yet. I'm still figuring out phpbb so will try and fix that as soon as I can. I've only just managed to get all the posts to show up at all!
Phil,
Posted: Tue Apr 13, 2004 10:09 am
by zoneminder
I have applied a mod to rebuild the search database so this should be fixed now. Searching for 'memory' now brings up more matches than you probably wanted.
Phil,
Posted: Tue Apr 13, 2004 10:19 am
by loop
Thank you Phil, if I knew that you moved forums just recently I wouldn't bother you at all, I know that it involves many problem resolving :)
Regards,
Darko
