No connection with zmninja
Detlef Paschke
Post by Detlef Paschke »
I'm probably just being stupid, but I just can't get zmninja to work.
Zoneminder works excellently via the web interface.
The API seems to be working.
curl -XPOST -d "user=USER&pass=PASS" http://192.168.0.80/zm/api/host/getVersion.json
{"version":"1.36.33","apiversion":"2.0"}
curl -XPOST -d "user=USER&pass=PASS" http://192.168.0.80/zm/api/host/login.json
{"access_token":"XXX","access_token_expires":7200,"refresh_token":"YYY","refresh_token_expires":86400,"credentials":"auth=","append_password":0,"version":"1.36 .33","apiversion":"2.0"}
curl -XPOST -d "user=USER&pass=PASS" http://192.168.0.80/zm/api/monitors.json
With User/Password Login there is a 401 error message and I assume that is where the problem lies.
{"success":false,"data":{"name":"Insufficient privileges","message":"Insufficient privileges","url":"\/zm\/api\/monitors.json","exception ":{"class":"UnauthorizedException","code":401,"message":"Insufficient privileges"}}}
curl -XGET http://192.168.0.80/zm/api/monitors.json?token=APITOKEN
With tokens, everything is issued as normal.
{"monitors":[{"Monitor":{"Id":1,...
I configured Zoneminder according to these instructions:
https://zmninja.readthedocs.io/en/lates ... ion-issues
After logging in, zmninja stays at the "loading..." screen and nothing else happens.
I can't do any configuration on zmninja because there is no configuration point (yet) and in Zoneminder everything is configured as listed in the FAQ.
I'm at a loss and don't know what else I can do. Does somebody has any idea?
Best regards
Detlef Paschke
Detlef Paschke
Re: No connection with zmninja
I tried a little further, but didn't get any further with the Android app.
I installed ZMNinja v1.6.009 for Windows and I can connect to the Zoneminder server and the cameras without any problems. Only the Adroid app is permanently at "loading..." after registration and without any progress.
I don't know what else to do, especially since there is no option for any settings in the Android app.
Best regards
Detlef Paschke
It may be that newer Android breaks it. Certainly lots of people complain that they can't even install it from the Play store.
We need to update it and release a new version .
