Gaps in recording, but camera not going down.
https://i.imgur.com/me1Utup.png
I've attached error logs.
I'm guessing something that's erroring out is causing the "drop" in recording. When i open the RTSP stream with VLC it never drops, it never drops in the vendor's app, it's only appearing to drop in zoneminder.
To those unfamiliar the dark areas in that bar graph are areas where no data is present, light areas have video data. I've confirmed it's writing to the drive.
Gaps in recording, errors in logs.
- Error.txt
- (3.73 KiB) Downloaded 20 times
- Warning.txt
- (35.82 KiB) Downloaded 15 times
Re: Gaps in recording, errors in logs.
I moved it from SMB to NFS and the symlink issue seems to have gone away.
this issues below persist.
Memory map file '/dev/shm/zm.mmap.2' does not exist in zmMemAttach. zmc might not be running.
DiskSpace: Event does not exist at /srv/dvr/zoneminder/events/1/23/09/07/12/56/03:ZoneMinder::Event: Cause => Continuous EndDateTime => 2023-09-07 12:57:07 Frames => 1486 Height => 1080 Id => 3632 Length => 63.69 MonitorId => 1 Name => Event-3632 Orientation => ROTATE_0 SaveJPEGs => 1 Scheme => Deep StartDateTime => 2023-09-07 12:56:03 StateId => 1 Width => 1920
Restarting capture daemon for Kitchen, time since last capture 47 seconds (1694110313-1694110266)
Restarting capture daemon for LivingRoom, time since last capture 46 seconds (1694110414-1694110368)
in the individual camera configs... what does source type do?
