Zoneminder and ReoLink 810A 4K - Incompatiple !?
Posted: Thu Sep 07, 2023 2:32 pm
It seems that you've been trying to get the Reolink 810A camera to work with Zoneminder for the past 3 weeks, but you're experiencing issues such as a delayed stream, and the Zoneminder web interface falling behind by several seconds. After about 24 hours, it's lagging 2-3 hours behind the current stream. So far, I've tried the following:
VLC stream works fine : rtsp://user:pass@IP/h265Preview_01_main
VLC stream works fine : rtsp://user:pass@IP/h264Preview_01_main
ZM does not record audio by default, right ?! Disable Audio in camera - no changes :/
Streamsource in ZM changed to H265 Stream - sems to work correctly, but when i try to watch a record ZM hangs => restart via ssh connection
i found some infoa about motion detection ( https://wiki.zoneminder.com/Dummies_Guide ) but my CPU does not raise very well when activating 4K analysis ?!
- Configure Camera via Webinterface to the minimal fps and resolution and bit rate => no changes streams lags again
- Configure zoneminder camera using TCP ( zoneminder hangs when using webinterface ), UDP Zoneminder lags, HTTP ( seems to camera passthrougt ) stream lags too but ZM interface works almost without lags
