1.37.41 Problems
pygr
1.37.41 Problems
Post by pygr »
I had a smoothly running 1.37.40, but I decided to install the latest from iconnor's PPA:
zoneminder/jammy,now 1.37.41~20230713172050-jammy arm64
Web access
http://<zoneminder_host_IP_address/zm>
returns
404 Not Found
. The underlying web server
http://<zoneminder_host_IP_address>
brings up the Apache2 default web page saying "It works!".
Executing
cat /var/log/zm/zmc_m1.log
shows the usual
07/15/23 10:22:25.165759 zmc_m1[421860].INF-zm_monitor.cpp/1737 [AV5426PMIR-S: 3000 - Capturing at 5.00 fps, capturing bandwidth 897641bytes/sec Analysing at 0.00 fps]
, but scrolling up reveals other problems
07/15/23 10:11:55.952387 zmc_m1[07/15/23 10:12:09.801859 zmc_m1[421860].INF-zmc.cpp/221 [Starting Capture version 1.37.41]
07/15/23 10:12:10.280071 zmc_m1[421860].ERR-zm_monitor.cpp/1050 [Couldn't create subscription! Connection refused, connect failed in tcp_connect()]
07/15/23 10:12:10.468962 zmc_m1[421860].ERR-zm_ffmpeg_camera.cpp/335 [Unable to open input rtsp://10.137.113.143:554/stream1 due to: Connection refused]
and scrolling further up shows lots and lots of
07/15/23 10:11:55.952329 zmc_m1[421579].ERR-zm_signal.cpp/50 [Got signal 7 (Bus error), crashing]
from which ZoneMinder recovered.
zmwatch.log shows
07/15/23 10:12:07.756444 zmwatch[421561].INF [main:100] [Restarting capture daemon for 1 AV5426PMIR-S, shared data not valid]
, but I don' know how to deal with that.
It occurred to me that the cause of the problems I'm seeing might be that the settings database is out of date, but no:
root@odroid# zmupdate.pl --user=root
Database already at version 1.37.41, update skipped.
Re: 1.37.41 Problems
Try
a2enconf zoneminder # reinstall
service apache2 reload # reinstall
If you ran as an update, those should have been handled already.
pygr
Post by pygr »
Hi Doug,
No I didn't run an update. I did
sudo apt remove zoneminder
to delete my custom version and then
sudo apt install
, which used iconnor's PPA.
I appreciate what you suggest, but it didn't work.
It looks like my installation is broken. The only file in /usr/share/zoneminder/www is zmc_m1.log and there is nothing in /usr/lib/zoneminder/cgi-bin.
I think the quickest and easiest thing to do is to start over with a fresh install.
I should have mentioned you need to do that sudo - e.g. sudo su
then the other two.
I works for me when I do apt remove as you did.
pygr
Post by pygr »
I was able to revert to a 1.37.40 build.
Whatever the problem is with 1.37.41, it isn't that "/Events" is tacked on to "onvif_url" in zm_monitor.cpp. The 1.37.40 build that's working for me now succeeds in getting a PullPoint subsciption with "http://<IP>/onvif/event_service/Events" for "full_url".
pygr
Post by pygr »
Success!
I tried again with a 1.37.41 deb package built from source following https://linux.how2shout.com/how-to-inst ... 20-04-lts/ to install it and I ran into the same problem as before: 404 Not Found error. However, your suggestion worked this time. As near as I can tell, I hadn't properly executed
a2enconf zoneminder
as super user in my earlier attempts.
Cool 8)
