service zoneminder status bug?
Rayj00
Post by Rayj00 »
Are the errors below valid?
joe@Rays-Win10:/mnt/c/WINDOWS/system32$ service zoneminder status
zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2023-06-09 17:19:53 EDT; 2h 52min ago
Process: 322 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
Main PID: 349 (zmdc.pl)
Tasks: 12 (limit: 19165)
Memory: 778.7M
CGroup: /system.slice/zoneminder.service
├─ 349 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
├─ 459 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
├─ 468 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
├─ 477 /usr/bin/perl -wT /usr/bin/zmwatch.pl
├─ 487 /usr/bin/perl -wT /usr/bin/zmupdate.pl -c
├─ 492 /usr/bin/perl -wT /usr/bin/zmtelemetry.pl
├─ 501 /usr/bin/perl -wT /usr/bin/zmstats.pl
└─1562 /usr/bin/zmc -m 2
Jun 09 19:56:55 Rays-Win10 zmc_m2[1166]: ERR [zmc_m2] [Unable to open input rtsp://192.168.1.52:554/stream1 due to: Server returned 401 Unauthorized (authorization failed)]
Jun 09 19:56:55 Rays-Win10 zmc_m2[1166]: ERR [zmc_m2] [Failed to prime capture of initial monitor]
Jun 09 19:57:00 Rays-Win10 zmc_m2[1166]: ERR [zmc_m2] [Unable to open input rtsp://192.168.1.52:554/stream1 due to: Immediate exit requested]
Jun 09 19:57:00 Rays-Win10 zmc_m2[1166]: ERR [zmc_m2] [Failed to prime capture of initial monitor]
Jun 09 19:57:03 Rays-Win10 zmc_m2[1189]: WAR [zmc_m2] [Monitor dimensions are 352x480 but camera is sending 1920x1080]
Jun 09 19:57:51 Rays-Win10 zmc_m2[1227]: WAR [zmc_m2] [Monitor dimensions are 640x480 but camera is sending 1920x1080]
Jun 09 20:02:43 Rays-Win10 zmc_m2[1400]: WAR [zmc_m2] [Monitor dimensions are 320x240 but camera is sending 1920x1080]
Jun 09 20:03:48 Rays-Win10 zmc_m2[1454]: WAR [zmc_m2] [Monitor dimensions are 1280x720 but camera is sending 1920x1080]
Jun 09 20:04:34 Rays-Win10 zmc_m2[1515]: WAR [zmc_m2] [Monitor dimensions are 640x480 but camera is sending 1920x1080]
Jun 09 20:04:59 Rays-Win10 zmc_m2[1562]: WAR [zmc_m2] [Monitor dimensions are 320x240 but camera is sending 1920x1080]
Re: service zoneminder status bug?
Good chance, yes.
Does that login work in VLC?
Rayj00
Post by Rayj00 »
Yes it works in VLC with RTSP credentials.
