I am a newbe with ZoneMinder. I have it installed (v1.36.33) on an internet facing Ubuntu 22.04 server.
I can access the control panel.
As I don't currently have any IP cameras, can someone detail how to add a USB camera?
At least I can continue experimenting.
Thanks,
Ray
USB Camera Help Needed
Re: USB Camera Help Needed
After thinking about this, I don't think using a USB camera locally will work with Zoneminder that is running remotely?
Am I correct with that assumption?
Thanks,
Ray
Thanks,
Ray
Upon further thinking, is zoneminder a local only application? I am assuming I can use a local IP camera remotely? Right or wrong?
It needs an IP address, yes.
There's software for that. Search webcam network or similar. The first hit is usually some gateway thing - skip that - $$.
ZM can use a webcam directly, locally.
Not sure what question you are answering?
So USB is local only. Makes sense.
Now, before I go out and purchase a couple IP cameras, does anyone have a tutorial on how to configure Zoneminder?
Thanks,
Ray
Thanks,
Ray
I guess I was unclear. There is software that will make a webcam (USB) visible at a designated IP address, while still usable at its host machine. The choices depend on the host OS. E.G.,So USB is local only. Makes sense.
https://alternativeto.net/software/yawcam/
As to
The basics are pretty self-explanatory, and automagic.a tutorial on how to configure Zoneminder?
This should help with adding the webcam - https://major.io/2015/02/07/using-zonem ... 70-webcam/
But again, USB is local only, right? At least that's what iConner told me? My Zoneminder is installed on a VPS.
In zoneminder, directly, yes.USB is local only, right?
