Invalid font file after updating from 1.34 to 1.36
Sciti
Post by Sciti »
After updating to 1.36 log spams
	Invalid font location: /usr/share/zoneminder/www/fonts/default.zmfnt
then i just wget default.zmfnt from github into this folder. Now log spams "Invalid font file". But fonts on web page looks ok, didn't see any occurrences of broken font on web pages.
Tried to turn on verbose logging, but no additional info was printed. What can i do with that?
Screenshot from 2023-06-05 14-52-21.png (101.14 KiB) Viewed 3227 times
Re: Invalid font file after updating from 1.34 to 1.36
Check FONT_FILE_LOCATION in config.
Make sure the font file is there.
Mine is /usr/share/zoneminder/fonts/ ,so slightly different.
Sciti
Post by Sciti »
Magic919 wrote: Mon Jun 05, 2023 12:17 pm Check FONT_FILE_LOCATION in config.
Thanks, found default.zmfnt at share/zoneminder/fonts/, changed FONT_FILE_LOCATION from zoneminder/www/fonts to just zoneminder/fonts, now it works. But something wrong with this github font...
It's probably the method you used to acquire the file from GitHub. You likely grabbed a web page.
Sciti
Post by Sciti »
Magic919 wrote: Mon Jun 05, 2023 1:47 pm It's probably the method you used to acquire the file from GitHub. You likely grabbed a web page.
Nope, i see zmfnt file in folder
Of course it's a file. It's a question of what it contains.
Run the file command on it and see what it reports.
file  /usr/share/zoneminder/fonts/default.zmfnt
Sciti
Post by Sciti »
Magic919 wrote: Fri Jun 09, 2023 9:18 am Of course it's a file. It's a question of what it contains.
Yeah, that was it! Didn't even thought about that, thanks
lbm
Post by lbm »
Thanks for the tip. Fixed it for me. My location is now "/usr/share/zoneminder/www/fonts/default.zmfnt". (This happened after I've updated from Debian11 to Debian12)
