Having Trouble While Installing This Software
TraceyRaynor
Post by TraceyRaynor »
Greetings to all, I am having a problem on my PC while installing this software ZoneMinder. After completing the downloading process when I try install this software, I came across this error "The application was unable to start correctly (0xc000012d). Click Ok to close the application." I have no idea what could be the issue. Does anyone have any idea about how can I able to fix it?
jeremyb
Re: Having Trouble While Installing This Software
Post by jeremyb »
Sound like you are trying to install this on windows. Although you can, its not as easy as clicking a button.
See: https://zoneminder.readthedocs.io/en/st ... s_wsl.html
Instructions are not completely there and I've never done an install of ZM on Windows with WSL.
TraceyRaynor
Thank you so much for your help. But after searching online I came across this useful guide. First I run SFC and DISM and updated the device driver. After doing the methods perfectly, the problem got solved. I had no longer any issues while installing the software.
