ZoneMinder with Docker/Portainer installation on Armbian Bullseye
lat123
Post by lat123 »
Hi all,
I am very new in Linux and Docker
I have to try install ZoneMinder with below Docker code like this:
docker pull yaoa/zoneminder-base
sudo docker run -d --name="Zoneminder" \
--net="bridge" \
--privileged="false" \
--shm-size="8G" \
-p 8443:443/tcp \
-p 9001:9001/tcp \
-e TZ="Asia/Ho_Chi_Minh" \
-e PUID="99" \
-e PGID="100" \
-e MULTI_PORT_START="0" \
-e MULTI_PORT_END="0" \
-v "/home/anhtu/Desktop/Zoneminder":"/config":rw \
-v "/home/anhtu/Desktop/Zoneminder/data":"/var/cache/zoneminder":rw \
Docker Zoominder show running Green
But I can not access to the 9001 port or 443 port but no respond
So I want to ask how to install ZoneMinder on Docker with ARM Bullseye ?
Thank you!
Here is the log files:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/00-reconfigure-user.sh
2023-05-25 11:56:26.470236452 [reconfigure-user] INFO Reconfiguring GID and UID
2023-05-25 11:56:26.989750119 [reconfigure-user] INFO User uid: 99
2023-05-25 11:56:27.007933059 [reconfigure-user] INFO User gid: 100
2023-05-25 11:56:27.018124032 [reconfigure-user] INFO Setting permissions for user www-data
2023-05-25 11:56:28.273275762 [reconfigure-user] INFO Setting permissions for user nobody at /log
cont-init: info: /etc/cont-init.d/00-reconfigure-user.sh exited 0
cont-init: info: running /etc/cont-init.d/10-log-config.sh
2023-05-25 11:56:28.321881618 [log-config] INFO Configuring log rotation with a maximum of 10 logs and a max log size of 1000000 bytes
cont-init: info: /etc/cont-init.d/10-log-config.sh exited 0
cont-init: info: running /etc/cont-init.d/20-system-config.sh
2023-05-25 11:56:28.350124195 [system-config] INFO Setting system timezone to Asia/Ho_Chi_Minh
2023-05-25 11:56:28.366836311 [system-config] INFO Configuring PHP Time
2023-05-25 11:56:28.645477744 [system-config] INFO Applying PHP Optimizations
2023-05-25 11:56:28.698376819 [system-config] INFO Redirecting PHP Logs to stdout
cont-init: info: /etc/cont-init.d/20-system-config.sh exited 0
cont-init: info: running /etc/cont-init.d/30-zm-config.sh
2023-05-25 11:56:28.737752390 [zm-config] FIRSTRUN Configuring ZoneMinder Configuration folder
2023-05-25 11:56:28.771529296 [zm-config] FIRSTRUN Configuring ZoneMinder Data folder
2023-05-25 11:56:28.810449148 [zm-config] INFO Configuring ZoneMinder db Settings
cont-init: info: /etc/cont-init.d/30-zm-config.sh exited 0
cont-init: info: running /etc/cont-init.d/40-msmtp-config.sh
2023-05-25 11:56:28.886995115 [msmtp-config] INFO Configuring msmtp settings...
cont-init: info: /etc/cont-init.d/40-msmtp-config.sh exited 0
cont-init: info: running /etc/cont-init.d/50-nginx-config.sh
2023-05-25 11:56:28.953597324 [nginx-config] INFO Configuring nginx settings...
cont-init: info: /etc/cont-init.d/50-nginx-config.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun fcgiwrap (no readiness notification)
services-up: info: copying legacy longrun mariadb (no readiness notification)
services-up: info: copying legacy longrun mariadb-configure (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
services-up: info: copying legacy longrun php-fpm (no readiness notification)
services-up: info: copying legacy longrun socklog (no readiness notification)
services-up: info: copying legacy longrun zoneminder (no readiness notification)
s6-rc: info: service legacy-services successfully started
[nginx] 2023-05-25 11:56:29.134506034 INFO Waiting for ZoneMinder to start
[zoneminder-service] 2023-05-25 11:56:29.202300935 INFO Waiting for Socklog to start
[php-fpm] 2023-05-25 11:56:29.174496493 INFO Starting PHP-fpm...
[fcgiwrap] 2023-05-25 11:56:29.186190791 INFO Starting fcgiwrap...
[mariadb-configure] 2023-05-25 11:56:29.197343701 INFO Waiting for MariaDB to start
[mariadb] 2023-05-25 11:56:29.231820665 INFO Waiting for Mariadb to start
[zoneminder-service] 2023-05-25 11:56:29.231378822 INFO Waiting for MariaDB to start
2023-05-25 13:53:47.500468288 [reconfigure-user] INFO Reconfiguring GID and UID
usermod: no changes
2023-05-25 13:53:47.619609524 [reconfigure-user] INFO User uid: 99
2023-05-25 13:53:47.637495535 [reconfigure-user] INFO User gid: 100
2023-05-25 13:53:47.651761551 [reconfigure-user] INFO Setting permissions for user www-data
2023-05-25 13:53:47.687899913 [reconfigure-user] INFO Setting permissions for user nobody at /log
2023-05-25 13:53:47.734906010 [log-config] INFO Configuring log rotation with a maximum of 10 logs and a max log size of 1000000 bytes
2023-05-25 13:53:47.760154472 [system-config] INFO Setting system timezone to Asia/Ho_Chi_Minh
2023-05-25 13:53:47.781354304 [system-config] INFO Configuring PHP Time
2023-05-25 13:53:48.077042388 [system-config] INFO Applying PHP Optimizations
2023-05-25 13:53:48.140173791 [system-config] INFO Redirecting PHP Logs to stdout
2023-05-25 13:53:48.177686350 [zm-config] INFO Configuring ZoneMinder db Settings
2023-05-25 13:53:48.245227015 [msmtp-config] INFO Configuring msmtp settings...
2023-05-25 13:53:48.323745917 [nginx-config] INFO Configuring nginx settings...
[nginx] 2023-05-25 13:53:48.470631959 INFO Waiting for ZoneMinder to start
[zoneminder-service] 2023-05-25 13:53:48.506903491 INFO Waiting for Socklog to start
[php-fpm] 2023-05-25 13:53:48.497087780 INFO Starting PHP-fpm...
[zoneminder-service] 2023-05-25 13:53:48.534330958 INFO Waiting for MariaDB to start
[mariadb-configure] 2023-05-25 13:53:48.520625287 INFO Waiting for MariaDB to start
[mariadb] 2023-05-25 13:53:48.527170428 INFO Waiting for Mariadb to start
[fcgiwrap] 2023-05-25 13:53:48.518104608 INFO Starting fcgiwrap...
lat123
Re: ZoneMinder with Docker/Portainer installation on Armbian Bullseye
Post by lat123 »
Hi all,
I have resolved my installation with running direct docker-compose (not through Portainer).
