Once set, cannot be unset from GUI.
First noticed in 1.37x but true in 1.36 also.
Filter bug "Unarchive all matches"
Re: Filter bug "Unarchive all matches"
I get the same issue in 1.36.33 (Ubuntu).
I fixed it (hopefully permanently) with a mysql command: `UPDATE Filters SET AutoUnarchive=0 WHERE Id=1;` (replace `1` with your filter ID).
I think this was also screwing up the filter query, because I was seeing a query like this in my debug logs.. `WHERE( [...] AND E.Archived = 0 ) AND ( E.Archived = 1 )`.
The `[...]` is the rest of my filter query, followed by "Archived Status - equal to - Unarchived only. It seems that having AutoUnarchive ticked will append the Archived=1 clause (because you can't unarchive something that isn't archived), but of course this create a query that can never yield results.
My filter works now! I wonder how many other topics on here about failed purges etc.. are due to this checkbox. The "Debug" button doesn't catch the error, but debug logging does.
Fix is now in master as well as proposed ppa. Will be included in 1.36.34.
