In Zoneminder master 1.37.37~20230324081257 , you can't create zm data base in fresh installation .
It is observerd that the file zm_create.sql is missing in the folder /usr/share/zoneminder/db/
It may be the reason for the issue .
Note:- I have copied zm_create.sql from previous version and added the file to the folder /usr/share/zoneminder/db/ and tried today 4/4/2023 with successful results .
ZoneMinder Master 1.37.37~20230324081257 has problems in fresh installation
- bkjaya1952
