Users access control
andrkac
Post by andrkac »
Hi. I have freshly installed instance of zm (1.36), on ubuntu 22.04.
Added two cameras and looks working, but only without users control (when OPT_USE_AUTH is disabled).
When I enable it, I cannot see any camera view. For all users, instead of mini view (console - cam list) or normal view I see only an icon saying 'missing image'.
It will work when I disable the option again.
What should I do?
Re: Users access control
You could start by checking the logs for zm and apache. One or both likely have clues.
andrkac
Post by andrkac »
Thank you.
The reason was simple - wrongly set timezone.
And as you said - logs pointed me into this.
However it is really courious that timezone issue blocks video...
Part of the lookup is time - so if it's wrong, no match, no video.
andrkac
Post by andrkac »
Ths is ok, but without user access control (unchecked OPT_USE_AUTH) wrong timezone is not a problem - I could see my cameras liveview without any issues.
