Can't add monitor: Path must be set a valid value
tr3b0r
Post by tr3b0r »
Trying to add a monitor to a new install of zoneminder
I can't switch from the General page.
and
when i try to save that it a popup message:
my_zoneminder_server says
Height must be set a valid value
Width must be set a valid value
                                                              OK
I did two zoneminder installs yesterday and it worked fine.
Help please
Re: Can't add monitor: Path must be set a valid value
Please give the exact steps to this problem.
How many monitors do you have?
Have you done any updates? What OS?
Check for javascript errors
lat123
Post by lat123 »
Hi Iconnor,
How can I check the javasciprt error ? Thank you.
By the way I have this error too
[zoneminder] 2023-05-25 16:31:42.263259957 local1.warn: May 25 16:31:42 web_php[344]: 5/25/23, 4:31:42 PM GMT+7.262190 web_php[344].WAR [172.20.0.1] [Specified value rtpRtsp not in contents: Array
[zoneminder] 2023-05-25 16:31:42.263325541 local1.warn: May 25 16:31:42 web_php[344]: (
[zoneminder] 2023-05-25 16:31:42.263327291 local1.warn: May 25 16:31:42 web_php[344]: [v4l2] => Video For Linux version 2
[zoneminder] 2023-05-25 16:31:42.263328708 local1.warn: May 25 16:31:42 web_php[344]: [v4l1] => Video For Linux version 1
[zoneminder] 2023-05-25 16:31:42.263339708 local1.warn: May 25 16:31:42 web_php[344]: )] at includes/functions.php line 484
[zoneminder] 2023-05-25 16:40:28.230187300 local1.err: May 25 16:40:28 web_php[340]: 5/25/23, 4:40:28 PM GMT+7.228099 web_php[340].ERR [172.20.0.1] [Unable to list network interfaces, status is '127'. Output was:<br/><br/>] at skins/classic/views/onvifprobe.php line 183
[zoneminder] 2023-05-25 16:40:28.247228107 local1.err: May 25 16:40:28 web_php[340]: 5/25/23, 4:40:28 PM GMT+7.246466 web_php[340].ERR [172.20.0.1] [Unable to list network interfaces, status is '127'. Output was:<br/><br/>] at skins/classic/views/onvifprobe.php line 199
[zoneminder] 2023-05-25 16:42:37.151074384 local1.err: May 25 16:42:37 web_php[343]: 5/25/23, 4:42:37 PM GMT+7.149912 web_php[343].ERR [172.20.0.1] [Unable to list network interfaces, status is '127'. Output was:<br/><br/>] at skins/classic/views/onvifprobe.php line 183
[zoneminder] 2023-05-25 16:42:37.162774583 local1.err: May 25 16:42:37 web_php[343]: 5/25/23, 4:42:37 PM GMT+7.162060 web_php[343].ERR [172.20.0.1] [Unable to list network interfaces, status is '127'. Output was:<br/><br/>] at skins/classic/views/onvifprobe.php line 199
shaklee3
Post by shaklee3 »
Hi, new user of ZM setting it up on Ubuntu for the first time. I have this same issue and cannot add any of my cameras. I don't see any javascript errors either.
shaklee3 wrote: Sun Jun 18, 2023 11:08 pm Hi, new user of ZM setting it up on Ubuntu for the first time. I have this same issue and cannot add any of my cameras. I don't see any javascript errors either.
What install procedure did you use?
