Invalid view console in ZM_WEB_HOMEVIEW does not exist
zemerdon
Post by zemerdon »
Went from 1.36.33 to 1.37.37
Keep getting...
/12/23, 2:10:23 PM GMT+10 web_php 1114 WAR Invalid view console in ZM_WEB_HOMEVIEW does not exist at /var/www/html/skins/classic/views/console.php /usr/share/zoneminder/www/includes/functions.php 2457
any ideas please?
makers_mark
Re: Invalid view console in ZM_WEB_HOMEVIEW does not exist
Post by makers_mark »
Is your DocumentRoot incorrect in the apache config?
Try commenting out this line (with a '#'):
DocumentRoot /var/www/html
And add this line:
DocumentRoot /usr/share/zoneminder/www
Restart Apache
Pjoms
Post by Pjoms »
zemerdon wrote: Sun Mar 12, 2023 4:12 am Went from 1.36.33 to 1.37.37
Keep getting...
Did you solve this?
I experience the same issue after upgrading from 1.37.2x to 1.37.37.
I´m not able to find either "DocumentRoot /var/www/html" or "DocumentRoot /usr/share/zoneminder/www" in any Apache config-files, but there is a line in the Zoneminder config-file under Apache that contains "/usr/share/zoneminder/www"
Beside all the errors in the Zoneminder log, I am not experience any other obvious issues.
zemerdon
Post by zemerdon »
Didn't solve, went back to 1.36.33 and works perfectly.
In 1.36.33 values for homeview were ?view=console I think... but in 1.37 It wuold just be console, and we specifically check for valid values. This code will be going into 1.36.34 as well as it is actually a security vulnerability.
