grey video capture at beginning of modect event
Posted: Sat Feb 25, 2023 4:36 pm
Hi All,
I have just setup a new VM (Manjaro) for Zoneminder (v1.36.33), and have setup 3 MODECT monitors. The VM has 8CPU core and 8GB RAM allocated. The Monitors are:
1 x local USB webcam (passed through form the host machine to the VM).
2 x remote feeds using ffmpeg source type.
All monitors are configured to capture 1280x720p at 15fps.
All monitors "storage" is setup to use video writer=encode, output codec=h264, encoder=libx264, crf=23, save JPEGs=disabled.
The issue I'm having, with all monitors is that when I replay event videos the first second or two is just showing grey blocky video and you can't see whatever it is that triggered the event. The grey blockiness goes away after the first second or two, but in some cases the thing that triggered the event has gone ...
I've tried playing around with all sorts of settings for the monitor setup, and the zones for each monitor, but I'm struggling to resolve the issue. Anybody got any ideas what could be causing this? Happy to provide more info on request.
Thanks in advance.
Justin
Thanks in advance.
Justin
