does purge when full only purge active cameras?
aarons6
Post by aarons6 »
so i was checking my drive and i noticed that an old camera that i took out and replaced still has some videos on one of my drives.
i have purge when full enabled and its at 99%.
when i go into zm and i click on the total events down at the bottom, it loads those old videos as the first few pages.
these old videos should have been purged months ago.. but they are still there.
any reason why they were skipped?
Re: does purge when full only purge active cameras?
Strange stuff sometimes happens...did you try running zmaudit.pl?
aarons6
Post by aarons6 »
dougmccrary wrote: Wed Feb 08, 2023 9:40 pm Strange stuff sometimes happens...did you try running zmaudit.pl?
its already running as normal.
Are they archived? ZM will not delete archived video.
aarons6
Post by aarons6 »
iconnor wrote: Thu Feb 09, 2023 1:12 am Are they archived? ZM will not delete archived video.
no they arent archived, i just turned the monitor off and put it to none.
So you made a new entry for the replacement camera.
Is the name you gave the new one the same as the old?
aarons6
Post by aarons6 »
dougmccrary wrote: Thu Feb 09, 2023 10:09 pm So you made a new entry for the replacement camera.
no, i just turned off the old camera and left it so it had the old videos, just incase i needed them.
but i figured it would eventually delete them to recover the drive space. but it didnt.
i just deleted them manually.
I guess that's worth a check.
pat2
Post by pat2 »
OT:
Doug, upgraded to the new v2 version of 1.36.33, released few hours ago, fyi it's available in the "proposed" repo
Isaac, thanks to release the xenial version too in the proposed repo
ZM 1.36.34 - 14 cameras on Orange Pi 5 (arm64) - Ubuntu Jammy 22.04
So, ran a test to see if old records would delete if the camera was simply turned off.
My result was "Yes, they are".
Don't know what happened in your case.
Purge when full filter does not by default look at monitor status. It should sort by age, deleting oldest first.
It might delete more events from 1 monitor over another, if they were more frequent, but literally it should delete oldest first.
Yes. That's been my experience, precisely.
I've found for my installs that purge at 95% disk full can be a problem. Especially with a many monitors recording. for a "normal" install I change the 95% to 85% which allows a free space cushion for the purge when full to catch up with the disk writes. By "normal" I mean the ZM install on a single disk. With the storage on a separate disk you can set up a purge when full filter for that disk.
