Use ffmpeg to retag video on capture?
ibrewster
Post by ibrewster »
I have a camera set up in zone minder that streams video in h.265 format. The camera is set up with a source type of "Ffmpeg" and a rtsp:// url. This all works as expected, I can view the camera live and it creates events, but when I download the event video (on my Mac) I can't play it in QuickTime Player. VLC plays the video fine, for what that is worth.
I have discovered that if I run the following command on the video, QuickTime Player can now play it without issue:
ffmpeg -i 1439962-video.mp4 -c copy -tag:v hvc1 output.mp4
So my question is this: if zone minder is really using Ffmpeg to capture the stream, as the source type of "Ffmpeg" would seem to indicate, is there a way I can set it to automatically use the "-c copy -tag:v hvc1" options when capturing/saving the stream?
Note that this is for a single camera, the other cameras I have set up do not use h.265.
Re: Use ffmpeg to retag video on capture?
Maybe it could go in Storage->Optional Encoder Parameters?
ibrewster
Post by ibrewster »
Good thought, but doesn't seem to work. Apparently that field needs things in key=value format, not command line args for one thing. I tried using tag:v=hvc1, but that didn't work, so it seems it's not just a format thing.
That said, after some more digging, I found this thread: viewtopic.php?t=31596, which suggested using filters, so I guess I'll give that a try. Though looking at the filters setup screen, I'm a bit confused as to how to make them run on new events - clicking the "list matches" button returns a list of old events, and I'd hate to have it run on every event every time it runs...
As you can see in the other thread, the filter will mark the events as done and not do them again.
ibrewster
Post by ibrewster »
Nope, I can see in the other thread that "the event will be marked that it has ben processed". That neither says or implies that it won't do it again - especially when the "list matches" button continually returns the same list, implying that it WILL do them again.
I'll take your word for it and see what happens though! :D
ibrewster
Post by ibrewster »
Ok, so the filter approach does seem to be working, with the caveat that all the videos seem to be cut off after a couple of minutes. Is there any chance that the filter runs before the event is complete?
EDIT: Just confirmed this is the case. Event ID 1629259 is a currently recording event, but my script already got and processed it. Guess the approach needs more work.
You could test for end time, for starters.
