https://youtu.be/hUqMUhgytyc
Some instructions for 22.04.
Installing 1.36 On Ubuntu 22.04
Re: Installing 1.36 On Ubuntu 22.04
Hi pat2
I followed you instructions and still have the errors. I reinstalled Ubuntu too.
The answers are in bold and underlined
The code for the errors are below too.
Thanks for trying to help me. I understand that this is not a help desk for Linux n00bs.
Hobs
Hobs
pat2 wrote: ↑Sat Jan 28, 2023 8:28 pm Hi Hobs,
this is Zoneminder, not the basic course of Ubuntu.
Please, don't give up, but probably you have to come back to Win/BlueIris.
Anyway, let's give it a try, I will give you directions.
- clear your disk and reinstall Ubuntu 22.04 then
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo sudo apt autoremove
sudo reboot
sudo dpkg-reconfigure tzdata (optional)
sudo apt install apache2
sudo nano /etc/apache2/apache2.conf (optional)
insert ServerName 127.0.0.1 (optional)
sudo apache2ctl configtest (pls take note of the answer)
Syntax OK
sudo systemctl restart apache2
Job for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xeu apache2.service" for details.
open the web browser (Firefox is recommended) and check http://LAN_ip_of_your_server, please post the printscreen of the web page
sudo apt install mysql-server
sudo apt install php libapache2-mod-php php-mysql
sudo nano /etc/php/8.1/apache2/php.ini (optional)
insert date.timezone = America/New_York (or whatever is your timezone) (optional)
sudo -i
add-apt-repository ppa:iconnor/zoneminder-1.36
apt-get update
apt-get upgrade
apt-get install zoneminder
chmod 740 /etc/zm/zm.conf
a2enmod cgi
a2enmod rewrite
a2enconf zoneminder
a2enmod expires
a2enmod headers
systemctl enable zoneminder
systemctl start zoneminder
open the web browser (Firefox is recommended) and check http://LAN_ip_of_your_server/zm, please post the printscreen of the web page
404 File NOT FOUND
hobs@Ubuntu-Server:~$ sudo systemctl restart apache2
hobs@Ubuntu-Server:~$ sudo apache2ctl configtest
Syntax OK
Try running the script as bbunge suggests: https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.36.x
over what you have. I *think* that will fix it.
If not, follow the whole wiki section from fresh.
Hi Hobs,
that's the routine I follow for 22.04 on my Odroid board and on a 22.04 virtual machine (on Win) that I occasionally use to make experiments.
And it works.
Currently my production environment is on 16.04, development environment is on 22.04.
Probably missing/mistaken any step in your 22.04 installation or you didn't restart from scratch (did you do?).
The strange it seems the config test is OK and you are able to reach the apache web page (that tells "It works").
But the system doesn't allow you to reload the apache service.
Before trying the instruction by Bunge or Isaac please, as suggested by the system, try to check
and
and let's know please.
It will provide more detail about the error. You have an issue on the Apache web server installation (that is the more easy part! ). Hope it will more clear after you will tell us the details.
Note: for your knowledge, currently you are stopped to the first phase of LAMP stack installation (LAMP stack is used by Zoneminder), In particular the installation of Apache, the service that allows the system to publish web pages (Zoneminder uses Apache services)
Please, see the apache installation instructions by DigitalOcean:
https://www.digitalocean.com/community/ ... untu-22-04
except the firewall matter (not important in your case), it's exactly what suggested with check on syntax and Apache web page.
If you try:
sudo nano /var/www/html/index.html
<!DOCTYPE html>
<html>
<head>
<title>Hello World!</title>
</head>
<body>
<h1>Hello World, I'm Hobs!</h1>
</body>
</html>
and save, you should be able, since the apache web page is working, to reach your new page at http://LAN_ip_of_your_server/index.html
For such damned reason the system is able to publish the apache web page and probably will be able for the Hello World page, but not able to reload the service..
And it works.
sudo systemctl status apache2.service
sudo journalctl -xeu apache2.service
If you try:
<!DOCTYPE html>
<html>
<head>
</head>
<body>
</body>
</html>
ZM 1.36.34 - 14 cameras on Orange Pi 5 (arm64) - Ubuntu Jammy 22.04
Hi pat2
I tried the code you suggested and posted the results below.
I also tried to follow the install instructions over on digitalocean and had the same results.
Maybe I should install 18.02
Hobs
The index page is the same as the Apache2 Default page.
Hobs
pat2 wrote: ↑Mon Jan 30, 2023 9:05 am Hi Hobs,
And it works.
Before trying the instruction by Bunge or Isaac please, as suggested by the system, try to checkCode: Select all
andCode: Select all
hobs@Ubuntu-Server:~$ sudo systemctl status apache2.service [sudo] password for hobs: × apache2.service - The Apache HTTP Server Loaded: loaded (/lib/systemd/system/apache2.service; enabled; preset: enabled) Active: failed (Result: exit-code) since Sun 2023-01-29 18:47:08 EST; 15h ago Docs: https://httpd.apache.org/docs/2.4/ CPU: 15ms Jan 29 18:47:08 Ubuntu-Server apachectl[110268]: (98)Address already in use: AH000> Jan 29 18:47:08 Ubuntu-Server apachectl[110268]: no listening sockets available, s> Jan 29 18:47:08 Ubuntu-Server apachectl[110268]: AH00015: Unable to open logs Jan 29 18:47:08 Ubuntu-Server apachectl[110265]: Action 'start' failed. Jan 29 18:47:08 Ubuntu-Server apachectl[110265]: The Apache error log may have mor> Jan 29 18:47:08 Ubuntu-Server systemd[1]: apache2.service: Control process exited,> Jan 29 18:47:08 Ubuntu-Server systemd[1]: apache2.service: Failed with result 'exi> Jan 29 18:47:08 Ubuntu-Server systemd[1]: Failed to start The Apache HTTP Server. Jan 29 22:35:56 Ubuntu-Server systemd[1]: apache2.service: Unit cannot be reloaded> Jan 29 22:45:50 Ubuntu-Server systemd[1]: apache2.service: Unit cannot be reloaded> lines 1-16/16 (END)
and let's know please.Code: Select all
hobs@Ubuntu-Server:~$ sudo journalctl -xeu apache2.service Jan 29 18:47:08 Ubuntu-Server apachectl[110268]: (98)Address already in use: AH000> Jan 29 18:47:08 Ubuntu-Server apachectl[110268]: no listening sockets available, s> Jan 29 18:47:08 Ubuntu-Server apachectl[110268]: AH00015: Unable to open logs Jan 29 18:47:08 Ubuntu-Server apachectl[110265]: Action 'start' failed. Jan 29 18:47:08 Ubuntu-Server apachectl[110265]: The Apache error log may have mor> Jan 29 18:47:08 Ubuntu-Server systemd[1]: apache2.service: Control process exited,> ░░ Subject: Unit process exited ░░ Defined-By: systemd ░░ Support: http://www.ubuntu.com/support ░░ ░░ An ExecStart= process belonging to unit apache2.service has exited. ░░ ░░ The process' exit code is 'exited' and its exit status is 1. Jan 29 18:47:08 Ubuntu-Server systemd[1]: apache2.service: Failed with result 'exi> ░░ Subject: Unit failed ░░ Defined-By: systemd ░░ Support: http://www.ubuntu.com/support ░░ ░░ The unit apache2.service has entered the 'failed' state with result 'exit-code'. Jan 29 18:47:08 Ubuntu-Server systemd[1]: Failed to start The Apache HTTP Server. ░░ Subject: A start job for unit apache2.service has failed ░░ Defined-By: systemd ░░ Support: http://www.ubuntu.com/support ░░ ░░ A start job for unit apache2.service has finished with a failure. ░░ ░░ The job identifier is 9241 and the job result is failed. Jan 29 22:35:56 Ubuntu-Server systemd[1]: apache2.service: Unit cannot be reloaded> Jan 29 22:45:50 Ubuntu-Server systemd[1]: apache2.service: Unit cannot be reloaded> lines 120-148/148 (END)
If you try:
<!DOCTYPE html>Code: Select all
!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/> <html xmlns="http://www.w3.org/1999/xhtml"> <!-- Modified from the Debian original for Ubuntu Last updated: 2022-03-22 See: https://launchpad.net/bugs/1966004 --> <head> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /> <title>Apache2 Ubuntu Default Page: It works</title> <style type="text/css" media="screen"> * { margin: 0px 0px 0px 0px; padding: 0px 0px 0px 0px; } body, html { padding: 3px 3px 3px 3px; background-color: #D8DBE2; font-family: Ubuntu, Verdana, sans-serif; font-size: 11pt; text-align: center; }
<html>
<head>
</head>
<body>
</body>
</html>
really strange error. It seems you are already using ports. Really strange for an installation from scratch.
Let's try with a fresh installation on 20.04. It's my way to be sure you will start from scratch.
And then please execute exactly the instruction by bunge.
Let us know please.
Let us know please.
