new install can't add camera, can't select source
sblight
Post by sblight »
I have a new install of Ubuntu server 22.04.1 LTS and Zoneminder v1.36.32, done the installs twice now.
I go to add a camera, in the "General" tab I can't select "Source", I can move around Options and change them for example timezone.
Stephen
Stephen
Manitoba, Canada
Re: new install can't add camera, can't select source
This tells me there is a javascript error somewhere stopping the rest of the javascript from working.
Check javascript console and view page source for weirdness.
sblight
Post by sblight »
bowser java console gives me
bootstrap.min.js:6 Uncaught Error: Bootstrap's JavaScript requires jQuery version 1.9.1 or higher, but lower than version 3
at bootstrap.min.js:6:216
at bootstrap.min.js:6:318
(anonymous) @ bootstrap.min.js:6
/zm/index.php?view=monitor#pills-source:1 Unchecked runtime.lastError: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received
Stephen
Manitoba, Canada
sblight
Post by sblight »
switched from Chrome bowser to Edge and it works
Stephen
Manitoba, Canada
We've seen that on upgrades, but you said it was a fresh install. Weird. You might find that chrome works if you clear your cache.
sblight
Post by sblight »
after clearing the cache it works in Chrome, thanks
Stephen
Manitoba, Canada
