I couldn't find the information on the forum so I'm asking my question
I can't create a filter to remove all events over a number of hours, 12 hours for example.
Thanks in advance for your help.
Delete event after a few hours
Re: Delete event after a few hours
Create a filter. Use startdatetime less than -2 hours. Also add a rule for Archive Status = UnArchived.
Thank you for your reply.
It works but I put "start time" so as not to have the date.
Thanks again.
Thanks again.
good evening,
Finally it does not work. I lose all recordings.
I don't understand, when I select start date time I have to choose a date and a time.
I just want to keep the last 24 hours.
I have attached a capture of the filter.
Thanks for your help.
- Capture d’écran de 2023-01-19 19-32-43.png (60.21 KiB) Viewed 216 times
enter "-3 hours" in the text box. Do not use the calendar popup.
