error
Heimo
error
Post by Heimo »
Hi all,
today during an update I have got following error message:
Get:5 https://zmrepo.zoneminder.com/debian/release-1.36 bullseye/ Release.gpg [862 B]
Err:5 https://zmrepo.zoneminder.com/debian/release-1.36 bullseye/ Release.gpg
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY A8C670C86F88B031
Fetched 2,253 B in 1s (1,567 B/s)
Reading package lists... Done
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://zmrepo.zoneminder.com/debian/release-1.36 bullseye/ Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY A8C670C86F88B031
W: Failed to fetch https://zmrepo.zoneminder.com/debian/re ... elease.gpg The following signatures couldn't be verified because the public key is not available: NO_PUBKEY A8C670C86F88B031
W: Some index files failed to download. They have been ignored, or old ones used instead.
Any idea what this means?
Kind regards.
Heimo
Re: error
Heimo
Re: error
Post by Heimo »
thanks a lot, it works.
Kind regards
Heimo
rolfb
Re: error on apt key
Post by rolfb »
Sorry to bump this topic, but this is what happened on my ZM as well.
However, the proposed solution iconner does suggest not work for me.
Small difference: I hit the error at
Err:11 http://zmrepo.zoneminder.com/debian/release-1.36 buster/ Release.gpg
But the missing pubkey has exact the same fingerprint.
The proposed solution writes a file /etc/apt/trusted.gpg.d/zmrepo.asc
But in that dir I only have gpg files for debian . (No asc files, no zm files)
NB: this is a turnkey zoneminder container on proxmox. Don't know if that makes it any different?
klmno
Re: error
Post by klmno »
I followed the above link and, as expected, ended up with a zmrepo.asc file in /etc/apt/trusted.gpg.d/. But, this did not solve the problem for me.
I'm running ZM on RPi OS 64-bit, so this is likely the cause. Instead, this is what worked for me:
curl -L https://zmrepo.zoneminder.com/debian/archive-keyring.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/zoneminder-archive-keyring.gpg >/dev/null
apt update
I tried to add this bit of info to viewtopic.php?p=129346#p129346 , but that thread appears locked.
Best regards.
