Page 1 of 1
Zoneminder Ninja
Posted: Tue Jan 10, 2023 4:02 am
by rharman
I have downloaded Zoneminder Ninja can you confirm which type of Authentication is best to use as the Username and Password I am using is working fine from my PC via the URL however it does not seem to be working via the Ninja. I get a message "Zoneminder Authentication Success" but I do not get further then the message "If this screen does not go away after a while, it is possible your APIs are not configured properly" I am using use basic authentication" . When I change to use ZM authentication I get Login validated but API failed
I don't have any problems accessing via the URL in a browser with the same login credentials
Re: Zoneminder Ninja
Posted: Tue Jan 10, 2023 10:08 am
by Magic919
I use ZM authentication.
Sounds like you should check your API in any case.
