ZM 1.36.32 - Home View functionality
pat2
Post by pat2 »
I'm using the Home View functionality. Very useful.
Inserting ?view=montage in Options->Users->Home View , after the Login I jump directly in the Montage view.
Usually I use a customized Layout (I named it "Final") in Montage View.
When I use my PC after login it jumps in the Montage View using the "Final" layout (desired behaviour), when I use other PCs it jumps in Montage View, but using the Freeform layout, not the "Final" layout (as desired).
I need to jump in Montage View using each time, from each PCs, my customized "Final" layout.
Is it a new functionality to be developed? or is there a workaround to obtain the desired functionality?
thanks
note: using Mozilla Firefox as browser
ZM 1.36.34 - 14 cameras on Orange Pi 5 (arm64) - Ubuntu Jammy 22.04
Re: ZM 1.36.32 - Home View functionality
Unfortunately selecting the layout is done with cookies.... it should also be available by url but that was never implemented.
I could get that into .33 easily enough... (taps the tips jar)
pat2
Post by pat2 »
I understand.
Thanks a lot, Isaac, for the future enhancement. Anyway, not a big issue.
Thanks Michele
