Page 1 of 1
ZM_event_notification with hooks/without hooks
Posted: Thu Nov 24, 2022 9:30 am
by streety111
What is the fundamental difference in setting zm_event_notification with and without hooks? What will I lose or gain from this?
Thanks for your reply in advance.
Re: ZM_event_notification with hooks/without hooks
Posted: Thu Jul 06, 2023 11:01 pm
by pepex7
The entire concept of hooks is to “influence” whether or not to actually send out a notification for a new event. If you are already using hooks, you are likely using the most popular hook that I wrote, which actually does object/person/face detection on the image(s) that constitute the event to make an intelligent decision on whether you really want to be notified of the event.
https://zmeventnotification.readthedocs ... iples.html
