9:16 camera image = problem?
NotSoWittyName
Re: 9:16 camera image = problem?
Post by NotSoWittyName »
Target Colorspace is (and has always been) set to 32 bit.
Thanks a lot for looking into this!
racelife
Post by racelife »
I am having this issue also. The camera is a reolink
fresh install yesterday on ubuntu server
pkt.dts(14737862) must be 	zm_videostore.cpp	1409
12/22/22, 1:37:40 PM MST	zmc_m3		10397	WAR	non increasing dts, fixing. our dts 14724677 stream 0 last_dts 14737862. reorder_queue_size=0
Have you tried upping the reorder_queue?
NotSoWittyName
FYI, didn’t help me, 9:16 is still not working for me.
You need Isaac to fix the mod16 problem for yours.
I made some fixes in master. Not sure if they will affect you as they were for 24bit... basically at this point, I am aware of an issue with rotation using 24bit, but am unable to reproduce your problem.
Please update to master and let us know what the status is.
racelife
Post by racelife »
Magic919 wrote: Fri Dec 23, 2022 8:05 am Have you tried upping the reorder_queue?
I'm on 1.36.32
I'm having a hard time finding this option. Can you direct me to where I can find it?
iconnor wrote: Fri Dec 23, 2022 4:06 pm I made some fixes in master. Not sure if they will affect you as they were for 24bit... basically at this point, I am aware of an issue with rotation using 24bit, but am unable to reproduce your problem.
I'm not using rotation if that matters... I am on 32bit also.
reorder queue settings will not solve crashes. It is an option for solved out of order dts/pts warnings. It goes in EncoderParameters. reorder_queue_size=something.
If a person is experiencing crashes, I suggest upgrading to master. That is where any fix is going to happen in the short term.
