HX-2PT1 PTZ control
wwalker
HX-2PT1 PTZ control
Post by wwalker »
I bought an HX-2PT1 from Hosafe. It is an HD camera that will do h264 or h265 at multipleresolutions and bit rates.
Audio and video seem to work fine.
For others, here are the URLs that work for RTSP:
rtsp://admin:PASSWORD@172.16.16.65:554/11
rtsp://admin:PASSWORD@172.16.16.65:554/12
My problem is that I can't figure out how to get PTZ to work.
It says it supports ONVIF, and it seems that the ONVIF control address is:
tcp
admin:PASSWORD@172.16.16.65:8080
any of the 8 direction buttons works, but it goes in that direction until it hits the stop. the OX in the middle doesn't stop it, nor does reclicking the button that started the movement.
Any idea where I should look next?
Thank you!
