SOLVED: Real IP behind reverse proxy (nginx) for logentrys (f.e. fail2ban)
nepixl
Post by nepixl »
SOLUTION IN THE LAST POST
Hello :)
at first: great project! I do really appreciate this project and the work behind. Awesome community ♥
And here is my problem:
I've set up a Ubuntuserver with ZoneMinder. Everything is working except the original IP from then external User inside the logs.
Surrounding:
I've set up a nginx reverse proxy -> Apache
Here the config:
 server {
    listen 443 http2;
    ssl on;
    ssl_certificate /cert.pem;
    ssl_certificate_key /privkey.pem;
    server_name *snipped*;
    access_log /var/log/nginx/nginx.*snipped*.*snipped*.log;
    error_log /var/log/nginx/nginx.*snipped*.*snipped*.log;
    #not sure if this is really needed:
      add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;";
      add_header X-Frame-Options "SAMEORIGIN";
      add_header X-Content-Type-Options "nosniff";
      add_header X-Permitted-Cross-Domain-Policies none;
      add_header X-XSS-Protection "1; mode=block";
 location / {
    proxy_pass http://*snipped*:81/;
    proxy_connect_timeout    300;
    proxy_send_timeout       300;
    proxy_read_timeout       300;
    send_timeout                     300;
       proxy_next_upstream error timeout invalid_header http_500 http_502 http_503 http_504;
       proxy_redirect off;
       proxy_set_header        Host            $host;
       proxy_set_header        X-Real-IP       $remote_addr;
       proxy_set_header        X-Forwarded-For $proxy_add_x_forwarded_for;
Access (even from zmNinja Pro)from external is working great. But I want to use Fail2ban which is already set up and running (with correct regex) but: how can I config that the real IP is showing inside the logs?
cat /var/log/zm/web_php.log | tail
2022/10/25 09:22:03.489700 web_php[70704].ERR [192.168.xxx.yyy] [Could not retrieve user c details] at /usr/share/zoneminder/www/includes/auth.php line 322
Any help is appreciated <3
Thank you and best regards,
pixl
nepixl
Re: Real IP behind revers proxy for logentrys (fail2ban)
Post by nepixl »
Since this is implemented,
return  (
              ( isset($_SERVER['HTTPS']) && $_SERVER['HTTPS'] == 'on' )
              or
              ( isset($_SERVER['HTTP_X_FORWARDED_PROTO']) and ( $_SERVER['HTTP_X_FORWARDED_PROTO'] == 'https' ) )
            ) ? 'https' : 'http';
my nginx config should look like this:
        proxy_set_header    X-Forwarded-Host $host;
        proxy_set_header    X-Forwarded-Proto $scheme;
I've tried that but still local IP in web_php.log.
Any ideas? :(
nepixl
Post by nepixl »
Bump.
No one an idea? :(
If I forget some information, please let me know.
Also I've searched this board for some solutions but nothing what is helping me.
Hopefully someone could help.
Thank you in advance,
BR
Change /usr/share/zoneminder/www/includes/logger.php line 368, replace REMOTE_ADDR with HTTP_X_FORWARDED_HOST
nepixl
Post by nepixl »
Awesome, thank you for your reply.
Now I see the fqdn of the server itself.
2022/10/25 16:30:40.020139 web_php[2868].ERR [sub.domain.xy] [Could not retrieve user trhrt details] at /usr/share/zoneminder/www/includes/auth.php line 322
my nginx config at the moment:
server {
    listen 443 http2;
    ssl on;
    server_name sub.domain.xy;
    access_log /var/log/nginx/nginx.*snipped*.access.log;
    error_log /var/log/nginx/nginx.*snipped*.error.log;
 location / {
  proxy_pass http://192.168.xxx.yyy:81/;
        proxy_set_header X-Forwarded-Server $host;
is this correct?! Any help is appreciated.
Thank you!
Edith: anything is working perfectly. App, Stream, load of server, .. like a charm! except the fail2ban log thing :(
Edith²: Do I have to change something on the apacheside? Usually not (its not my first reverse proxy but this time it gets hard :D)
nepixl
Post by nepixl »
Since noone wants explain that correctly, I'll do this for the next one.
At first: IT IS NOT NECESSARY TO EDIT Zoneminder FILES
THIS IS NOT NEEDED!
Zoneminderversion: v1.36.31
Edit nginx conf
default.conf or what you want #default nginx site
vim /etc/nginx/conf.d/default.conf
add proxy_set_header for location
location / {
        proxy_set_header X-Forwarded-For $remote_addr;
create a new conf file for Apache
vim /etc/apache2/conf-available/remoteip.conf
and add
RemoteIPHeader X-Forwarded-For
RemoteIPTrustedProxy 192.168.xxx.yyy #IP from proxy_pass
Activate this conf with
a2enconf remoteip
service apache2 restart
And now /var/log/zm/web_php.log and $SERVER['REMOTE_ADDR'] have the real IP:
2022/10/26 06:40:29.443236 web_php[5218].ERR [217.85.xxx.yyy] [Could not retrieve user testlogin details] at /usr/share/zoneminder/www/includes/auth.php line 322
Fail2Ban Test:
Running tests
Use failregex filter file : zoneminder, basedir: /etc/fail2ban
Use log file : /var/log/zm/web_php.log
Use encoding : UTF-8
Results
Failregex: 2 total
|- #) [# of hits] regular expression
| 1) [2] ^\s*web_php\[\d+\]\.ERR \[<HOST>\].*includes/auth.php
| 192.168.xxx.yyy Wed Oct 26 06:40:11 2022
| 217.85.yyy.xxx Wed Oct 26 06:40:29 2022
Used regex for fail2ban config:
failregex = ^\s*web_php\[\d+\]\.ERR \[<HOST>\].*includes/auth.php
F2B is now working and banning (if active)
Thanks for this project.
Have a good time :)
Greetings
